Hello everyone! For a while I have been looking to migrate my nextion jeedom to HA! Uploading data from HA to NEXTION is ok Create 2 buttons under NEXTION to activate a relay under HA, it’s ok There I’m stuck, I’ve done lots of tests but with no results… I have a b0 button on NEXTION, and I would like the color of the button to change depending on the state of the button. I can’t even make a color change without depending on a state using directly: it.set_component_background_color(“b0”,“63488”); without condition… ditto for this line which should change the gauge value (unconditionally) it.set_component_value(“z0”, 100);
display:
- platform: nextion
uart_id: uart_0
update_interval: 6s # Pas de réel besoin de rafraichissement
#touch_sleep_timeout: 15
wake_up_page: 0
brightness: 95%
lambda: |-
it.set_component_background_color("b0","63488");
it.set_component_value("z0", 100);
if(id(bilot).state){
it.set_component_background_color("b1","1024");
} else{
it.set_component_background_color("b1","63488");
Thanks you !
