NFC "Digital" vinyl player
I’ve been using @adonno’s excellent tag-reader code to create a way to start music without getting the phone out of my pocket. Instead of using the credit sized cards that needs to be printed on as well, I thought it could be cool to use the vinyls I already have (which I rarely use TBH, just because it is so damn cumbersome).
So I’ve made a little shelf, and whenever I place one of my records on it, music starts playing from Deezer on my speakers.
To manage the tags, I’m just using the Tags menu in HA, and then I’m saving the “Deezer-id” of the album (e.g. 59853992 = Pink Floyd - Dark side of the moon) as the Tag ID, and then I have an automation forwards the ID to the speaker and start the music. This makes it very easy to add more records later.
Here is a video showing how it works:
Video
Here is how I add new tags:
Video
Here’s is the ESPHome config for an ESP32 Dev. board. The NFC reader is a pn532 and the LED used is a SK6812.
esphome:
  platform: ESP32
  board: esp32dev
  # Automatically add the mac address to the name
  # so you can use a single firmware for all devices
  name_add_mac_suffix: false
  on_boot:
    priority: -10
    then:
    - wait_until:
        api.connected:
    - logger.log: API is connected!
    - light.turn_on:
        brightness: 100%
        green: 100%
        red: 0%
        blue: 0%
        white: 0%
        flash_length: 5000ms
improv_serial:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "tagreader_ap"
    password: "12345678"
# Enable the captive portal for inital WiFi setup
captive_portal:
substitutions:
  friendly_name: TagReader
# Enable logging
logger:
  # level: VERY_VERBOSE
  # level: VERBOSE
# Enable Home Assistant API
api:
  services:
  - service: write_tag_random
    then:
    - lambda: |-
        static const char alphanum[] = "0123456789abcdef";
        std::string uri = "https://www.home-assistant.io/tag/";
        for (int i = 0; i < 8; i++)
          uri += alphanum[random_uint32() % (sizeof(alphanum) - 1)];
        uri += "-";
        for (int j = 0; j < 3; j++) {
          for (int i = 0; i < 4; i++)
          uri += "-";
        for (int i = 0; i < 12; i++)
        auto message = new nfc::NdefMessage();
        message->add_uri_record(uri);
        ESP_LOGD("tagreader", "Writing payload: %s", uri.c_str());
        id(pn532_board).write_mode(message);
  - service: write_tag_id
    variables:
      tag_id: string
    then:
    - lambda: |-
        uri += tag_id;
    - light.turn_on:
        brightness: 100%
        red: 100%
        green: 0%
        blue: 0%
        white: 0%
        flash_length: 3000ms
    - wait_until:
        not:
          pn532.is_writing:
  - service: clean_tag
    then:
    - lambda: 'id(pn532_board).clean_mode();'
    - wait_until:
        not:
          pn532.is_writing:
  - service: cancel_writing
    then:
    - lambda: 'id(pn532_board).read_mode();'
# Enable OTA upgrade
ota:
  - platform: esphome
i2c:
  scan: False
  frequency: 400kHz
pn532_i2c:
  update_interval: 350ms
  on_tag:
    then:
    - homeassistant.tag_scanned: !lambda |
        if (!tag.has_ndef_message()) {
          ESP_LOGD("tagreader", "No NDEF");
          return x;
        auto message = tag.get_ndef_message();
        auto records = message->get_records();
        for (auto &record : records) {
          std::string payload = record->get_payload();
          size_t pos = payload.find("https://www.home-assistant.io/tag/");
          if (pos != std::string::npos) {
            return payload.substr(pos + 34);
        ESP_LOGD("tagreader", "Bad NDEF, fallback to uid");
        return x;
    - light.turn_on:
        brightness: 100%
        red: 0%
        green: 0%
        blue: 0%
        white: 100%
        flash_length: 1500ms
binary_sensor:
  - platform: status
    entity_category: diagnostic
light:
  - platform: neopixelbus
    type: GRBW
    variant: SK6812
    pin: GPIO27
    num_leds: 1
    flash_transition_length: 500ms
    restore_mode: ALWAYS_OFF
switch:
  - platform: restart
    name: "Living Room Restart"
And lastly, here is the austomation I use for my speaker (using the Bang & Olufsen integration):
alias: Mozart Deezer album tag reader
triggers:
  - event_type: tag_scanned
    trigger: event
conditions: []
actions:
  - data:
      media_content_type: deezer
      media_content_id: album:{{ trigger.event.data.tag_id }}
      entity_id: media_player.beosound_theatre_12345678
    action: media_player.play_media
This is awesome! Good work!
Where are you putting the tags? What’s that display?
Hi Dave,
I’m putting a NFC sticker inside the cover in the lower left corner of the vinyl cover (seen from the front, around 1 cm from each side). Some might not want to “ruin” their covers by adding a sticker inside, and in that case I’d suggest to use plastic covers and put the sticker inside that instead :slight_smile:
The display is a Lametric Time :slight_smile:
i wish there was a way to detect when a tag is removed. that could the stop the playing of the music
Hi Adonno, in my use-case I actually wouldn’t use it. The entire reason to do this (for me), was to be able to enjoy the covers, also while listening :slight_smile: So I like that I can take them off the player-shelf and have a look while listening. That being said, there are times where that exact feature would be really nice :+1:
Nowadays I’m using the relatively newly launched deep-link functionality to start music on my Apple TV. Then I also get lyrics! :slight_smile:
I love this, I am very interested in the support, did you make it? or did you buy it, if so, could you tell me where? I already have the sensor and it works, I just need the support :slight_smile:
THANKS
Hi :slight_smile:
I only made the measurements, but my father-in-law did the hard work :wink:
I’ll happily share the measurements of this stand. The trickiest part is to find the balance on the depth of the slot where the record is placed; the LPs must obviously be able to lean again the wall without falling down, but also the record can’t be in a too relaxed angle, so that the NFC chip is too far away from the reader.
Also, the part where you place your reader behind must be QUITE thin (approx 1mm).
Let me get back with some rough measurements.
That sounds like an amazing project—kudos to you and your father-in-law! I’d love to get the measurements whenever you’re ready. The details you mentioned about the slot depth and the thinness for the NFC reader are super helpful already.
Do you know if there have been any updates/developments for this?
Aw man, I completely forgot about this. Sorry!
Here are some rough measurements of the shelf:
33,6cm wide. 8cm tall. 5,1cm deep.
The thickness of the MDF where the NFC reader is placed is 1-1,5mm thick.
one option i can think of is placing back a blank with something u like that can be displayed and it can have another NFC that can stop the music.
at least a few NFC readers since 2024 support on_tag_removed action
My TagTuner supports this action.
