If I stick a NFC tag on my phone, how can I use this to trigger an automation ? In other words, how will HA know that a specific NFC tag arrives home ? How does HA read the tag ?
Does your phone have an NFC Reader?
You can also build a Reader with an ESP32 Controller and place inside of the door.
There are NFC tags out there which constists some unique number inside them.
1.When a reader reads the specific tag, you can initiate the automation.
- If your phone has a reader, your phone can call home assistant to initiate an automation when it reads a specific tag.
As previous post, you can build esp based readers and initiate automation from esp
You can also put a label on your phone and put your phone to esp reader to initiate an automation, it is same as option 1.
Thanks !!! Other than building a reader myself (not something I am comfortable with) is there a NFC reader on the market ?
No affiliation: Tag Reader Sandwich Version – Adonno
