Hello, everyone.
I added an NFC tag to the Home Assistant and created automation when I read the tag my light turned on. The issue is, that I always have to click on a pop-up to the automation run. Is that normal, is that a way I can tap the iPhone, and the automation runs without clicking on the screen?
Perfectly normal for iPhones unfortunately. There’s plenty of threads about it here if you search around. I believe there’s a workaround using shortcuts, but I don’t use iPhones, so have a search in these forums to see if you can land on something.
