NFC tag scanned event doesn't provide a valid device_id on android
I just started playing with NFC tags and use a input_text helper to verify things. I want to set the mobile phone’s device id to this input_text helper so that I can use it for later notifications. But it seems the device_id I record is the first few chars of the actual one. Any idea why this happens?
Here is an automation
alias: Test nfc tag
  - platform: event
    event_type: tag_scanned
    event_data:
      tag_id: <actual tag id>
  - service: input_text.set_value
      value: |
        {{ trigger.event.data.device_id }}
      entity_id: input_text.used_by
So after a trigger and a quick check, the value input_text.used_by is set to 2f... of 16 chars. But the actual device id contains 32 chars. Actually, this device_id embedded in trigger.event.data is only the first half of the actual device id. Now I cannot use input_text.used_by's value in other notification workflows because it will fail (invalid device id). Not sure why it has to trim off the second half.
Is that a bug in the companion app?
I am using HA app installed from play store @ 2022.10.2-full. My HA instance is @ 2022.10.5.
Supposed to be fixed by this Incorrect device_id in tag scanning events fired by mobile app integration · Issue #82554 · home-assistant/core · GitHub
how do you do this?
