NFC TagReader specific automations for specific tagid
Hi, I have 3 different readers built with the Adonno project. I would like to use the same tag-id to open different ports based on the reader reading it.
I found this workaround using the reader led in the conditions, but I don’t really like it as a solution.
- id: 'xxxxx'
  alias: TAG READER PORTA UFFICI INTERNA
  description: Lettore Cassettina Chiavi
  - platform: tag
    tag_id: FD-20-D8-3F
  - platform: tag
    tag_id: 96-12-EF-D4
  - platform: tag
    tag_id: E1-7D-83-1C
  condition:
  - condition: device
    type: is_on
    device_id: 8814a592d1a4d55db88700240e579ee9
    entity_id: light.tagreader_led_3
    domain: light
  - service: switch.toggle
    data: {}
      entity_id: switch.uffici2
    enabled: true
  mode: single
I’ve tried with variables, like in the example below, but it doesn’t work
- id: 'xxxxxxx'
  alias: TEST TEST
  max_exceeded: silent
  variables:
    device_id: d7d19ee18e89f2cfa7cf5a2815a1e7b1
  - platform: tag
    tag_id: FD-20-D8-3F
  - platform: tag
    tag_id: 96-12-EF-D4
  - platform: tag
    tag_id: E1-7D-83-1C
  condition:
  - '{{ trigger.event.data.tag_id in trigger }}'
  - '{{ trigger.event.data.device_id in variables }}'
    data: {}
      entity_id: switch.sonoff_xxxxx
  mode: single
I am a newbye, can you help me?
Thank you
i think this can work if you use an event type trigger (tag_scanned)
something like this
  - platform: event
    event_type: tag_scanned
condition: []
  - if:
      - condition: template
        value_template: >-
          {{ trigger.event.data.tag_id in trigger }}= 'device id from device you
          want'
    then:
      - type: turn_on
        device_id: xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
        entity_id: switch.xxxxx
        domain: switch
i am currently not at home, so i cant check, but i will see later as i am in the proces of building automations through my nfc readers and will need this aswell.
i will do some looking around probably tonight and will post progress here…
but using the IF condition on the device_id triggering the scan seems like the way to go to me
It’s easy enough, seems this this is a standard function: Automation Trigger - Home Assistant (home-assistant.io)
just been testing this, works like a charm for my use case
(same action in different rooms depending on what tag gets scanned in which room)
so in your case this would become something like this:
- id: 'xxxxx'
  - platform: tag
    tag_id:
      - "FD-20-D8-3F"
      - "96-12-EF-D4"
      - "E1-7D-83-1C"
    device_id:
      - "8814a592d1a4d55db88700240e579ee9"
  condition: []
      data: {}
  mode: single
@KennyHec
You have been very kind! I can confirm that it works perfectly …
Often the simplest things are always the best solution.
I was mind-traveling in far more complicated solutions.
Thanks again.
Same here mate, i guess that the thing with Home Assistant, sometimes you expect it to be difficult. Tuth be told, there is so much possible it’s sometimes easy to miss how simple things can be.
glad to hear i could help someone for once :wink:
Feel free to tag that post as ‘answer’ it help people navigating through the forums to find answers…
