Hi created some NFC tags in HA wrote on the tag using the Ha android app.
All works except very long delay.
When I scan tag it says on my Samsung S20 Ultra processing tag and takes up to 10 seconds to activate.
If I go to the created automation in HA and press execute it executes instantly.
Seen about phone putting ha app to sleep so removed anything to do with in battery optimizations.
But at same time shouldn’t be the problem since I tried 4 times back and forth between app execute command and scan tag one after the other and results are the same.
Also scanned tag while in HA app.
What can be causing the ± 10 second delay only when scanning?
BTW this is on all tags I have
