If I get to buy some NFC tags, will it be possible to create automations when I scan them with an android phone? For example, place a TAG near a garage door to disable Alarm
I think it can be done via the Automate or Tasker APP using webhook.
Erik
just noted that the app now has a setting named “NFC Tags” and I thought this can be used for such instances.
Just tested it myself, cause i had the same idea. You can indeed scan a tag to have an automation running
thanks I never used tags … can I use something like these?
Yes, i would expect it works.
I used these
and
The cards im using so i can print emblems on them. They are hanging around my house (planning to) Some i use for lights, other for alarms and Music.
thanks for your input !
The automations vĂa NFC work just fine but… Why are they so slow? 5 - 10 seconds could be an eternity to light up a room
5 secs its horrible
It’s working for me within 1 seconds
