Hi there,
wanted to share my fresh knowledge with you guys.
Unfortunately we Android users need to unlock our phone prior scanning NFC tags - I cannot change that (but maybe it is possible by rooting the device - anyone in the comments?).
But at least I got rid of the annoying popup from the NFC service ‘want to open the link’. To solve this you need an additional NFC writer app.
Do the following steps:
Add the NFC tag via the app as usually
Get an NFC writer app like “NFC tools” - fortunately free
Open NFC tools and scan the freshly written tag
at the very bottom you will find a dataset like “https:/home-assistant.io/tag/[the tag id]” copy this url into the clipboard
Change to the Write tab in the app.
5.a) Add a custom URL and place the URL from the clippboard
5.b) (Now the important part): Add a second dataset, now use application and choose then the homeassistant app: should loke like “io.homeassistant.companion.android”
5.c) Write the NFC tag -
Change the the read tab and try to scan the NFC tag, it should look like this:
Exit now the NFC tools app and you should be able to finally scan the NFC tag without the annoying popup
