Hi guys
I have had my setup working over SSL and port 8123 for months now without issue on a Rpi. I have just installed nginx for access to all my other services like sonarr, radarr etc and it works great with the built in authentication. However, I am trying to get it to work with HassIO and failing miserably. I just keep getting either 404 or bad gateway errors.
I have rebuilt HassIO on Ubuntu 18.04 without SSL and it works fine internally through http://192.168.10.60:8123. Nginx & Tautulli runs on 192.168.10.31. Sonarr/Radarr/NZBGet runs on 192.168.10.30.
I now want to access HA through my nginx at https://home.mydomain.com/ha. After trying all sorts of config I either get a bad gateway or 404 error. Here is my config, can anyone help?
server {
listen 80 default_server;
listen [::]:80 default_server;
server_name <redacted> 192.168.10.31;
return 301 https://$server_name$request_uri;
server {
# SSL configuration
listen 443 ssl http2 default_server;
listen [::]:443 ssl http2 default_server;
include /etc/nginx/snippets/strong-ssl.conf;
ssl_certificate /etc/letsencrypt/live/<redacted>/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/<redacted>/privkey.pem;
# Root location
root /var/www/html;
# Add index.php to the list if you are using PHP
index index.html index.htm index.nginx-debian.html;
# Basic Auth to protect the site
auth_basic "Restricted";
auth_basic_user_file /etc/nginx/.htpasswd;
# Change the client side error pages (4xx) to prevent some information disclosure
error_page 401 403 404 /404.html;
# First attempt to serve request as file, then as directory,
# then fall back to displaying a 404.
location / {
try_files $uri $uri/ =404;
# Deny access to .htaccess files, if Apache's document
# root concurs with nginx's one
location ~ /\.ht {
deny all;
# Let's Encrypt Webroot plugin location -- allow access
location ^~ /.well-known/acme-challenge/ {
auth_basic off;
autoindex on;
# Location settings for reverse proxy; enable those you wish to use
# by removing the # from the section between the location line and the last }
# NZBGet
location /nzbget {
proxy_pass http://192.168.10.30:6789;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
# Sonarr
location /sonarr {
proxy_pass http://192.168.10.30:8989;
# Radarr
location /radarr {
proxy_pass http://192.168.10.30:7878;
# Tautulli
# Turn off auth for Tautulli remote
location /tautulli {
auth_basic "off";
include /etc/nginx/uwsgi_params;
uwsgi_pass unix:/tmp/app.sock;
proxy_pass http://127.0.0.1:8181;
proxy_set_header X-Forwarded-Host $server_name;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header X-Forwarded-Ssl on;
location /api {
auth_basic "off";
# HA
location /ha {
proxy_pass http://192.168.10.60:8123;
I don’t have anything set in my configuration.yaml apart from my password.
