I’m trying to access to my HA through nginx with https but doesn’t work.
If I access to http://private.ip:8123 works, but if I access to https://public.ip:443 the web stops on the first page before the login “Initializing” and the url is:
I have HA in raspbian server1, and NGINX in raspbian server2. THe two servers are in the same subnet without any comunication problems.
My HA configuration.yaml is:
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: 0
longitude: 0
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: UTC
# Customization file
customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
use_x_forwarded_for: true
trusted_proxies:
- 192.168.1.210
base_url: public.ip
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Sensors
# Weather prediction
- platform: yr
# Text to speech
tts:
- platform: google
# Cloud
cloud:
logger:
default: debug # default logging level
logs:
homeassistant.components.device_tracker.asuswrt: debug # suppress IPv6-related warnings; see https://github.com/home-assistant/home-assistant/issues/2814
homeassistant.components.light.yeelight: info
homeassistant.helpers.entity: debug # Hue bridge throws lots of errors
group: !include groups.yaml
script: !include scripts.yaml
This is my nginx.conf:
user www-data;
worker_processes 1;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# server_names_hash_bucket_size 64;
# server_name_in_redirect off;
include /etc/nginx/mime.types;
default_type application/octet-stream;
# SSL Settings
ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
access_log /var/log/nginx/access.log;
error_log /var/log/nginx/error.log;
# Gzip Settings
#gzip on;
#gzip_disable "msie6";
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# gzip_types text/plain text/css application/json application/javascript text/xml application/xml application/xml+rss text/javascript;
# Virtual Host Configs
include /etc/nginx/conf.d/*.conf;
include /etc/nginx/sites-enabled/*;
include /etc/nginx/proxy_params;
And this is my nginx domain conf:
server {
# Update this line to be your domain
server_name public.ip;
# These shouldn't need to be changed
listen 80 default_server ipv6only=off;
return 301 https://$host$request_uri;
server {
# Ensure these lines point to your SSL certificate and key
ssl_certificate /etc/letsencrypt/live/public.ip/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/public.ip/privkey.pem;
# Use these lines instead if you created a self-signed certificate
# ssl_certificate /etc/nginx/ssl/cert.pem;
# ssl_certificate_key /etc/nginx/ssl/key.pem;
# Ensure this line points to your dhparams file
#ssl_dhparam /etc/nginx/ssl/dhparams.pem;
listen 443 default_server ipv6only=off;
add_header Strict-Transport-Security "max-age=31536000; includeSubdomains";
ssl on;
ssl_ciphers "EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH:!aNULL:!eNULL:!EXPORT:!DES:!MD5:!PSK:!RC4";
ssl_session_cache shared:SSL:10m;
proxy_buffering off;
location / {
# auth_basic "Zona restringida";
# auth_basic_user_file /etc/nginx/.htpasswd;
proxy_pass http://private.ip:8123;
proxy_set_header Host $host;
proxy_redirect http:// https://;
proxy_http_version 1.1;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
I tried too with auth_basic enabled but the result is the same.
When I try to access I only see this in the nginx logs:
XX.XX.XX.XX - AUTH_BASIC_USER [28/Dec/2018:14:00:51 +0100] "GET / HTTP/1.1" 200 2874 "-" "Mozilla/5.0 (Windows NT 6.1; rv:64.0) Gecko/20100101 Firefox/64.0"
XX.XX.XX.XX - AUTH_BASIC_USER [28/Dec/2018:14:00:51 +0100] "GET /frontend_latest/app-6a2aa396.js HTTP/1.1" 499 0 "https://public.ip/" "Mozilla/5.0 (Windows NT 6.1; rv:64.0) Gecko/20100101 Firefox/64.0"
XX.XX.XX.XX - AUTH_BASIC_USER [28/Dec/2018:14:03:21 +0100] "GET /auth/authorize?response_type=code&client_id=https%3A%2F%2Fpublic.ip%2F&redirect_uri=https%3A%2F%2Fpublic.ip%2F%3Fauth_callback%3D1&state=eyJoYXNzVXJsIjoiaHR0cHM6Ly9qYWlyby5jZiIsImNsaWVudElkIjoiaHR0cHM6Ly9qYWlyby5jZi8ifQ%3D%3D HTTP/1.1" 302 0 "https://public.ip/" "Mozilla/5.0 (Windows NT 6.1; rv:64.0) Gecko/20100101 Firefox/64.0"
Any ideas about why doesn’t works and how I can resolve this?
Many thanks in advance.
