Hello, i’m trying to include an iframe_panel for node red into homeassistant i’m using the following config in configuration.yaml
panel_iframe:
nodered:
title: 'Node red'
url: https://nodered.url:1880
icon: mdi:nodejs
Further i’m running homeassistant behind nginx with the following config
location / {
proxy_pass http://192.168.1.103:8123;
proxy_set_header Host $host;
proxy_redirect http:// https://;
proxy_http_version 1.1;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
location /nodered {
proxy_pass http://192.168.1.103:8123/nodered;
This is working perfect on my internal network. However, if i’m accessing my external url and go to the iframe it says ttps://nodered.url:1880 can’t be reached and may be down. Is there a way to solve this?
