Can you please make the share directory read/write so I can redirect my access and error logs to the Share directory. This will make it easier for me to access them with out having to ssh in to home assistant box and the use docker exec to access the container.
I am using the following in the Customize feature to host a static website but can not enable logging to the share directory because it’s read only.
active: true
default: nginx_proxy_default*.conf
servers: nginx_proxy/*.conf
/share/nginx_proxy/www.example.com.conf
server {
# error_log /share/log/www.example.com/error.log warn;
# access_log /share/log/www.example.com/access.log;
listen 80;
server_name example.com www.example.com;
return 301 https://www.example.com$request_uri;
server {
server_name example.com;
listen 443 ssl http2;
ssl_session_timeout 1d;
ssl_session_cache shared:MozSSL:10m;
ssl_session_tickets off;
ssl_certificate /ssl/fullchain.pem;
ssl_certificate_key /ssl/privkey.pem;
ssl_dhparam /data/dhparams.pem;
ssl_protocols TLSv1.2 TLSv1.3;
ssl_ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384;
ssl_prefer_server_ciphers off;
server {
server_name www.example.com;
root /share/html/www.example.com;
location / {
index index.html index.htm;
try_files $uri $uri/ /index.html =404;
