Hi All, really hope someone can help here…
I am running latest HASSio (OS 6.1) with Core 21.7.3 on a NUC
I have just added the “NGINX Home Assistant SSL proxy” Add-on and have the following options set in the add-on:
domain: mydomain.co.uk
certfile: fullchain.pem
keyfile: privkey.pem
hsts: max-age=31536000; includeSubDomains
cloudflare: false
customize:
active: false
default: nginx_proxy_default*.conf
servers: nginx_proxy/*.conf
Were my domain is of course set to my actual domain. I have also modified my configuration.yaml as follows:
http:
## ssl_certificate: /ssl/fullchain.pem
## ssl_key: /ssl/privkey.pem
## ip_ban_enabled: true
## login_attempts_threshold: 4
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.4
- 127.0.0.1
- ::1
I was initially note sure what IP’s to add here but as the reverse proxy is on the actual NUC then I have read quite a few posts recently the I need to add 172.0.0.1 & ::1 - I have no idea as to why exactly but not sure its relevant to my issue at this stage. I was also not sure what the actual NGINX IP address was but then I found the following error:
A request from a reverse proxy was received from 172.30.33.4, but your HTTP integration is not set-up for reverse proxies
So I assume I have set all the required settings correctly, however I am unable to proceed as following the configuration.yaml edit (as show above) I now get the following error:
Configuration invalid
Component error: trusted_proxies - Integration 'trusted_proxies' not found. Component error: use_x_forwarded_for - Integration 'use_x_forwarded_for' not found.
I am really not sure how to proceed from here, I am pretty sure its me being an idiot (again) but any input would be much appreciated at this point.
Thanks all
