Nginx: Logging in to Home with Truster Networks.. login aborted. Your computer is not allowed:
I just upgraded from Home Assistant 2021.4.6 —> Home Assistant 2021.7.
Immediately after doing this, when I try to login to the web interface, I get the error message below:
Unabletologin
My Home assistant instance (Virtualbox VM runnning on a Windows 10 host) is behind a Nginx reverse proxy.
I’ve never had this issue before. Nothing has changed on my network or setup other than upgrading Home Assistant.
Configuration.yaml:
http:
  use_x_forwarded_for: True
  trusted_proxies:
    - 192.168.1.1
    - 192.168.1.2
api:
homeassistant:
  auth_providers:
    - type: trusted_networks
      trusted_networks:
        - 192.168.1.0/24
        - 172.16.0.0/12
        - fe00::/8
Nginx.conf
    server {
            listen 443 ssl http2;
            listen [::]:443 ssl http2;
            ssl_certificate     ./ssl/fullchain.cer;
            ssl_certificate_key ./ssl/cert.key;
            server_name  ha.myurl.com;
            location / {
                proxy_pass http://192.168.1.101:8123;
                proxy_set_header Accept-Encoding "";
                proxy_http_version 1.1;
                proxy_set_header Upgrade $http_upgrade;
                proxy_set_header Connection $http_connection;
Thanks in advance for your help.
You probably need to add this to your `auth_providers:
    - type: homeassistant
Is your proxy server address one of these?
- 192.168.1.1
- 192.168.1.2
What do you see in the HA logs?
Your proxy also needs to add the “X-Forwarded-For:” header, but I don’t know exactly what triggers that in the NGINX config.
Thanks for the suggestions. It doesn’t make any difference when making these changes (below) after restarting nginx/home assistant. Whatever the problem is, my configuration was just fine for all previous versions of Home Assistant in the last couple of years.
The only thing I can do is log in with: Home Assistant Local username/password. I’m curious what changed in Home Assistant in the last couple of versions to break trusted network for nginx.
configuration.yaml
homeassistant:
  auth_providers:
      trusted_networks:
        - 192.168.1.0/24
        - 172.16.0.0/12
        - fe00::/8
nginx.conf:
    server {
            location / {
                proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
No related errors or warnings in the log.
May be related to this: Reject trusted network access from proxies by elupus · Pull Request #52388 · home-assistant/core · GitHub
Other than that, I don’t know what more to do.
Thanks for the link. sigh I’m really having a hard time keeping up with all the things that break with each update.
I just ran into this same issue while trying to update from an older release to 2021.8. Did you ever find a fix/workaround?
So sorry for the late response. My issue was because I had proxy_set_header X-Forwarded-Proto $scheme; missing in my nginx configuration for Home Assistant. Thanks to @rccoleman for the tip! Below is what my the configuration looks like now:
configuration.yaml
http:
  trusted_proxies:
    - 192.168.1.2
api:
homeassistant:
  auth_providers:
      trusted_networks:
        - 192.168.1.0/24
        - 172.16.0.0/12
        - fe00::/8
nginx.conf
    server {
            location / {
                proxy_set_header X-Real-IP $remote_addr;
