Nginx problem with Frigate 14
Hi folks,
For some reason I’m unable to run Frigate on my HA.
It seems to do with something Nginx related.
Here is my error log:
2024-08-26 18:35:15.929716436  [INFO] The go2rtc service exited with code 1 (by signal 0)
2024-08-26 18:35:16.087308059  [INFO] Starting NGINX...
  File "/usr/local/nginx/get_tls_settings.py", line 20, in <module>
    config: dict[str, any] = yaml.safe_load(raw_config)
  File "/usr/local/lib/python3.9/dist-packages/yaml/__init__.py", line 125, in safe_load
    return load(stream, SafeLoader)
  File "/usr/local/lib/python3.9/dist-packages/yaml/__init__.py", line 81, in load
    return loader.get_single_data()
  File "/usr/local/lib/python3.9/dist-packages/yaml/constructor.py", line 49, in get_single_data
    node = self.get_single_node()
  File "/usr/local/lib/python3.9/dist-packages/yaml/composer.py", line 36, in get_single_node
    document = self.compose_document()
  File "/usr/local/lib/python3.9/dist-packages/yaml/composer.py", line 55, in compose_document
    node = self.compose_node(None, None)
  File "/usr/local/lib/python3.9/dist-packages/yaml/composer.py", line 84, in compose_node
    node = self.compose_mapping_node(anchor)
  File "/usr/local/lib/python3.9/dist-packages/yaml/composer.py", line 133, in compose_mapping_node
    item_value = self.compose_node(node, item_key)
  File "/usr/local/lib/python3.9/dist-packages/yaml/composer.py", line 82, in compose_node
    node = self.compose_sequence_node(anchor)
  File "/usr/local/lib/python3.9/dist-packages/yaml/composer.py", line 110, in compose_sequence_node
    while not self.check_event(SequenceEndEvent):
  File "/usr/local/lib/python3.9/dist-packages/yaml/parser.py", line 98, in check_event
    self.current_event = self.state()
  File "/usr/local/lib/python3.9/dist-packages/yaml/parser.py", line 392, in parse_block_sequence_entry
    raise ParserError("while parsing a block collection", self.marks[-1],
yaml.parser.ParserError: while parsing a block collection
  in "<unicode string>", line 10, column 8:
           - path: rtsp://admin:KenzoPoes12 ...
expected <block end>, but found '<block mapping start>'
  in "<unicode string>", line 11, column 9:
            roles:
2024/08/26 20:35:16 EOF
2024-08-26 18:35:16.162410028  [INFO] Service NGINX exited with code 1 (by signal 0)
2024-08-26 18:35:16.944186625  [INFO] Preparing new go2rtc config...
2024-08-26 18:35:16.991968273  [INFO] Got IP address from supervisor: 192.168.178.174
2024-08-26 18:35:17.037135991  [INFO] Got WebRTC port from supervisor: 8555
2024-08-26 18:35:17.174096375  [INFO] Starting NGINX...
            roles:
2024/08/26 20:35:17 EOF
2024-08-26 18:35:17.333917535  [INFO] Service NGINX exited with code 1 (by signal 0)
Anyone knowing how to fix this issue?
this is an issue with your config, you should paste the config
same for me…
2024-09-01 13:50:53.110828776 [INFO] Got WebRTC port from supervisor: 8555
2024/09/01 15:50:53 EOF
2024-09-01 13:50:53.153056578 [INFO] Service NGINX exited with code 1 (by signal 0)
are you sure it is a frigate.yml error ???
i got the error when update to Current version: 0.14.1
no modification to frigate.yml
