I see people have this error but no resolution. I have a nginx proxy server that is sending traffic to my HA behind a pfsense and I get Error: Invalid client id
Nginx proxy server 2.2.2.2
pfsense WAN IP 1.1.1.1
port forward 8123 - 8123
HA IP 10.0.0.17
http://1.1.1.1:8123 works (PFsense wan port)
http://10.0.0.17:8123 works (internal network IP)
http://2.2.2.2 I get Error: Invalid client id
nginx.conf
user root;
worker_processes 2;
#error_log logs/error.log;
#error_log logs/error.log notice;
#error_log logs/error.log info;
pid /var/run/nginx.pid;
events {
worker_connections 1024;
http {
include mime.types;
default_type application/octet-stream;
sendfile on;
keepalive_timeout 0;
client_body_buffer_size 10K;
client_header_buffer_size 1k;
client_max_body_size 1G;
large_client_header_buffers 2 1k;
gzip on;
gzip_http_version 1.1;
gzip_vary on;
gzip_comp_level 1;
gzip_proxied any;
gzip_types text/plain text/css application/json application/x-javascript text/xml application/xml application/xml+rss text/javascript application/javascript image/svg+xml;
upstream homeassistant {
server 1.1.1.1:8123;
keepalive 64;
server {
listen 80 default_server;
listen [::]:80 default_server;
server_name _;
return 301 https://$host$request_uri;
server {
listen 443 ssl;
listen [::]:443 ssl;
server_name sub.ha-domain.com;
add_header Strict-Transport-Security "max-age=31536000; includeSubdomains";
# add_header 'Cache-Control' 'no-store, no-cache, must-revalidate, proxy-revalidate, max-age=0';
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_prefer_server_ciphers on;
ssl_ciphers "EECDH+ECDSA+AESGCM:EECDH+aRSA+AESGCM:EECDH+ECDSA+SHA384:EECDH+ECDSA+SHA256:EECDH+aRSA+SHA384:EECDH+aRSA+SHA256:EECDH:DHE+AESGCM:DHE:!RSA!aNULL:!eNULL:!LOW:!RC4:!3DES:!MD5:!EXP:!PSK:!SRP:!DSS:!CAMELLIA:!SEED";
ssl_session_tickets off;
ssl_certificate /etc/ssl/certs/nginx-selfsigned.crt;
ssl_certificate_key /etc/ssl/private/nginx-selfsigned.key;
proxy_buffering off;
location / {
proxy_pass http://homeassistant;
proxy_set_header Host $host;
proxy_http_version 1.1;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "Upgrade";
location /api/websocket {
proxy_pass http://homeassistant/api/websocket;
proxy_set_header Connection "upgrade";
# cloudflare ip restoration https://support.cloudflare.com/hc/en-us/articles/200170786-Restoring-original-visitor-IPs-Logging-visitor-IP-addresses-with-mod-cloudflare-
# include /etc/nginx/conf.d/*.conf;
ha configuration.yaml
http:
server_port: 8123
use_x_forwarded_for: true
trusted_proxies:
- 192.168.1.1 # openwrt's nginx server
- 10.0.0.17
- 1.1.1.1
- 2.2.2.2
- 10.1.1.1
- 127.0.0.1
ip_ban_enabled: false
login_attempts_threshold: 500
base_url: 2.2.2.2:8123
