I use the Nginx Proxy Manager Add On to create and install my SSL certificates from Let’s Encrypt.
On every restart of my HA host (I run a VM on Proxmox with Home Assistant Operating System) the docker container running Nginx Proxy Manager Add On the gets a different IP, which breaks the HA http/trusted_proxies configuration and I can’t reach the web frontend.
Every time I have ssh into HA, check the logs for the new IP and edit configuration.yaml http/trusted_proxies config.
Is there a way to tell the add on / docker container which IP it should use?
Or is there a way to set up a wildcard IP for allowed proxies? I tried 172.30.33.0, but that didn’t work.
Thanks for your help.
