Hi all, kind of lost here, tried many options without success.
On a proxmox server Im running HA as a VM and nginx proxy manager as a container. Using my own domain I set up cloudfare DNS, so I can access my services online. All is working great, forwarding ports 443 and 80 to the nginx proxy manager ip container
Now I can access my ha instance going to https://ha.mydomain.com , I reach the login page, but using the correct credentials it shows UNABLE TO CONNECT TO HOME ASSISTANT.
Connecting locally this is the error:
ip list is:
HA: 192.168.1.4
Nginx: 192.168.1.58
My relevant config.yaml is: (Have tried many combinations without success)
homeassistant:
auth_providers:
- type: homeassistant
- type: trusted_networks
trusted_networks:
- 192.168.1.0/24
allow_bypass_login: true
http:
ip_ban_enabled: false
use_x_forwarded_for: true
trusted_proxies:
- 172.70.0.0/24
#- 192.168.1.55
- 192.168.1.0/24
This is the nginx config
Any help more than welcome, I know this is a little mistake in the configuration but cant find what!
