Hi, I have HAOS installed and yesterday I upgraded to the latest version of the operating system and since then I no longer have access to HA in the usual way. Checking I have seen that the nginx proxy manager addon is stopped and if I try to start it it tells me that port 80 is being used.
Failed to start add-on
Port '80' is already in use by something else on the host.
Checking what is on the port I think the process that is occupying it is something from s6 that looks like it is something from the supervisor.
➜ ~ lsof -i :80
1 /package/admin/s6-2.12.0.2/command/s6-svscan 0 /dev/null
1 /package/admin/s6-2.12.0.2/command/s6-svscan 1 pipe:[21687]
1 /package/admin/s6-2.12.0.2/command/s6-svscan 2 pipe:[21688]
1 /package/admin/s6-2.12.0.2/command/s6-svscan 3 /run/service/.s6-svscan/lock
1 /package/admin/s6-2.12.0.2/command/s6-svscan 5 /run/service/.s6-svscan/control
1 /package/admin/s6-2.12.0.2/command/s6-svscan 6 /run/service/.s6-svscan/control
1 /package/admin/s6-2.12.0.2/command/s6-svscan 7 anon_inode:[signalfd]
16 /package/admin/s6-2.12.0.2/command/s6-supervise 0 /dev/null
16 /package/admin/s6-2.12.0.2/command/s6-supervise 1 pipe:[21687]
16 /package/admin/s6-2.12.0.2/command/s6-supervise 2 pipe:[21688]
16 /package/admin/s6-2.12.0.2/command/s6-supervise 3 /run/service/s6-linux-init-shutdownd/supervise/lock
16 /package/admin/s6-2.12.0.2/command/s6-supervise 4 /run/service/s6-linux-init-shutdownd/supervise/control
16 /package/admin/s6-2.12.0.2/command/s6-supervise 5 /run/service/s6-linux-init-shutdownd/supervise/control
16 /package/admin/s6-2.12.0.2/command/s6-supervise 6 anon_inode:[signalfd]
19 /package/admin/s6-linux-init-1.1.2.0/command/s6-linux-init-shutdownd 0 /dev/null
19 /package/admin/s6-linux-init-1.1.2.0/command/s6-linux-init-shutdownd 1 pipe:[21687]
19 /package/admin/s6-linux-init-1.1.2.0/command/s6-linux-init-shutdownd 2 pipe:[21688]
19 /package/admin/s6-linux-init-1.1.2.0/command/s6-linux-init-shutdownd 4 /run/service/s6-linux-init-shutdownd/fifo
19 /package/admin/s6-linux-init-1.1.2.0/command/s6-linux-init-shutdownd 5 /run/service/s6-linux-init-shutdownd/fifo
25 /package/admin/s6-2.12.0.2/command/s6-supervise 0 /dev/null
25 /package/admin/s6-2.12.0.2/command/s6-supervise 1 pipe:[21687]
25 /package/admin/s6-2.12.0.2/command/s6-supervise 2 pipe:[21688]
25 /package/admin/s6-2.12.0.2/command/s6-supervise 3 /run/s6-rc:s6-rc-init:jBeHjF/servi
Is this happening to anyone. And if so is there any solution?
Regards
