Dear Community
I want to enable HTTPS on my HA by installing/using the Nginx proxy manager Add-on. My Router-IP is NOT accessible from the internet for now, I want it local because there are several things running not as smooth as they can (should?) be. E.g. annoying Popups "you are…!!)
Installation (MariaDB and) Add-on went fine.
I have a proxy host “homeassistant-jhopmann.de” running, added this to my router-dns
… and everything working fine so far.
Now I follow the guide to add HTTPS by “Request a new SSL certificate”.
The logs state as following:
*[11/15/2023] [9:01:05 PM] [Nginx ] › ℹ info Reloading Nginx*
*[11/15/2023] [9:01:10 PM] [SSL ] › ℹ info Requesting Let'sEncrypt certificates for Cert #3: homassistant-jhopmann.com*
*[11/15/2023] [9:01:10 PM] [SSL ] › ℹ info Command: certbot certonly --config "/etc/letsencrypt.ini" --cert-name "npm-3" --agree-tos --authenticator webroot --email "[email protected]" --preferred-challenges "dns,http" --domains "homassistant-jhopmann.com" *
*[11/15/2023] [9:01:17 PM] [Nginx ] › ℹ info Reloading Nginx*
*[11/15/2023] [9:01:17 PM] [Express ] › ⚠ warning Command failed: certbot certonly --config "/etc/letsencrypt.ini" --cert-name "npm-3" --agree-tos --authenticator webroot --email "[email protected]" --preferred-challenges "dns,http" --domains "homassistant-jhopmann.com" *
*Saving debug log to /data/logs/letsencrypt/letsencrypt.log*
*Some challenges have failed.*
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /data/logs/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details.
I tried to search for the “letsencrypt.log”, but there is none. I do not have letsencrypt. Is this a prerequisite?
(I tried to install … but does not help + no logs too)
Even the path to it does not exists.
I was also not able to find any certbot -installation. So I would assume the command failed because of missing certbot.
But which is needed? I found that even apt-get is not available.
My setup:
Hardware:
Raspberry PI 4
Version | core-2023.11.2 |
Installationstyp | Home Assistant OS |
Entwicklung | false |
Supervisor | true |
Docker | true |
Benutzer | root |
Virtuelle Umgebung | false |
Python-Version | 3.11.6 |
Betriebssystemfamilie | Linux |
Betriebssystem-Version | 6.1.21-v8 |
CPU-Architektur | aarch64 |
Zeitzone | Asia/Bangkok |
Konfigurationsverzeichnis | /config |
Home Assistant Community Store
GitHub API | ok |
GitHub Content | ok |
GitHub Web | ok |
GitHub API Calls Remaining | 5000 |
Installed Version | 1.33.0 |
Stage | running |
Available Repositories | 1337 |
Downloaded Repositories | 6 |
HACS Data | ok |
Home Assistant Cloud
Angemeldet | false |
Zertifikatsserver erreichbar | ok |
Authentifizierungsserver erreichbar | ok |
Home Assistant Cloud erreichbar | ok |
Home Assistant Supervisor
Host-Betriebssystem | Home Assistant OS 11.1 |
Update-Channel | stable |
Supervisor-Version | supervisor-2023.11.3 |
Agent-Version | 1.6.0 |
Docker-Version | 24.0.6 |
Speicherplatz gesamt | 56.6 GB |
Speicherplatz genutzt | 8.6 GB |
Gesund | true |
Unterstützt | true |
Board | rpi4-64 |
Supervisor-API | ok |
Versions-API | ok |
Best regards Jörg
