Hey, I use Nginx (globally) as a reverse proxy and run hass as a docker container. I tried to follow the hass-instructions for Nginx
My target is to access hass via the internet via a subdomain:
**example.com/hassio**
The access in the local network via IP and Port works: **http://192.168.2.126:8123/**
If I call the example.com/hassio
it’s just loading the blue pillar on the top. So I looked in the nginx error log and it connot be loaded the frontend (extraction):
2020/04/20 09:27:11 [error] 1917#1917: *11 open() "/usr/share/nginx/html/frontend_latest/hass-icons.31f02e18.js" failed (2: No such file or directory), client: 84.176.157.201, server: example.com, request: "GET /frontend_latest/hass-icons.31f02e18.js HTTP/2.0", host: "example.com", referrer: "https://example.com/hassio"
How can I link the right folder and to which one?
