Since I’m using a edgerouter lite I never managed to get duckdns to work again.
I decided to give a try with NGINX SSL proxy addon.
The instalation seems quite simple (used this setup).
but even this first part doesn’t work.
![image](http://community-assets.home-assistant.io/original/3X/c/6/c6d29537ec9c92b995ab01e390ab69ed3bff8102.png)
I can’t even proceed to the SSL part.
I’m port forwarding port 80 and 443 for the hassio ip.
![image](http://community-assets.home-assistant.io/original/3X/a/2/a2c6a0a11dcd26510d7737eb292372372aed3ffa.png)
Could it be a firewall rule? Hassio is on a VLAN (40) with some limitation, but I guess this is not the problem. Any sugestion?
Thanks in advance
