Trying to get NGINX to accept incoming on 443 and redirect to 8123
This works
server {
server_name ha.x.y.net;
ssl_certificate /etc/letsencrypt/live/ha.x.y/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/ha.x.y/privkey.pem;
listen [::]:443 ssl default_server ipv6only=off;
#listen [::]:8123 ssl default_server ipv6only=off;
add_header Strict-Transport-Security "max-age=31536000; includeSubdomains";
ssl on; # Uncomment if you are using nginx < 1.15.0
ssl_protocols TLSv1 TLSv1.1 TLSv1.2;
ssl_ciphers "EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH:!aNULL:!eNULL:!EXPORT:!DES:!MD5:!PSK:!RC4";
ssl_prefer_server_ciphers on;
ssl_session_cache shared:SSL:10m;
proxy_buffering off;
location / {
proxy_pass http://10.19.49.2:8123;
proxy_set_header Host $host;
proxy_redirect http:// https://;
proxy_http_version 1.1;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
But
This doesnt work (times out in browser)
#--DAZ 1-4-2020 Reverse proxy to HomeAssistant on VPN
server {
listen [::]:443 ssl;
server_name ha.x.y;
return 301 $scheme://ha.x.y:8123$request_uri;
server {
#listen [::]:443 ssl default_server ipv6only=off;
location / {
I tried adding the bump below to the first server but that didnt work either?
What am I doing wrong?
