Unfortunately I have big problems setting up the reverse proxy.
I especially need the function to use the Ecowitt integration.
Everything worked when used with Fritzbox and rebind protection there.
Now I have a new router (Mikrotik). It is not so easy to install the rebind protection here.
I’ve been trying to do this with the hairpin option for weeks.
Unfortunately unsuccessful.
Now I remembered NGINX as an option.
Here is the biggest problem. As soon as I made the necessary changes
cors_allowed_origins:
- https://google.com
- https://www.home-assistant.io
ip_ban_enabled: true
login_attempts_threshold: 5
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24
and As soon as I delete the lines:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pemt
Alexa can no longer access the home assistant. Hope someone has an idea.
Thx
