Nibe SMO S40
Hello
I am new to HA so don’t know anything about code parts etc.
However I have my Nibe SMO S40 heatpump in HA and all working so far.
However I am trying to set up a notification to alter me when the heating starts and when it goes back to idle.
I can find some sensors with options like heat, off, cool, etc but nothing really works.
Any ideas what entity I should be using?
On a side note I also found the energy monitor entity but there is no info for it… Any ideas?
Did you figure out what entity to use for controlling if the SMO S40 should “heat” or not?
Just got my SMO S40 integrated so I am interested in hearing about other peoples experience on how to control it from HA.
Hi Korttoma,
Try: climate.nibe_43988_s1_room
Thanks for your reply. I did not find the exact same entity but I found one called “climate.climate_system_s1” I guess it is the same one. All I can do with that one is to set Auto, Heat/Cool and Heat so it does not seem like I can use it to completely block my heat pump.
I did however find that if I set the entity “number.operating_mode_42744” (SMOS40 Operating mode) to 2 it block my Heat Pump.
