First time poster here.
First of all thanks for the great work on HA and all the integrations!
I’ve migrated from Nibe Uplink to MyUplink, all went well but with Nibe Uplink I could see if my heatpump (F1255) was heating or cooling. I can’t see this option in the MyUplink intergration. Is there a way to see if the pump is heating or cooling?
HA version: 2024.7.2
MyUplink Intergration Version: 1.2.4
Sadly, MyUplink custom integration doesn’t yet reach quality of NibeUplink official integration. I upgraded my F1255 from NibeUplink to MyUplink with high hopes, MyUplink offers lot of everything for everyone in very difficult to understand and manage-format.
Really hope MyUplink would reach same high quality user experience as @elupus et al created in NibeUplink integration.
For example, I use F1255 outdoor temp sensor to calculate degree days for energytracker and heating control. NibeUplink used to gave this temp at 0,1°C accuracy, MyUplink gives only 0,5°C accuracy, which is probably “accurate enough”, but looks stupid since I use this measured temp also to show outdoor temp in my HA-tablet. Nowadays, my place has only temp readings ending at .1°C and .6°C, which is highly unlikely to be real I don’t know, if this is limitation in Nibe MyUplink firmware, or integration.
Hmm, migrated today from NibeUplink to myUplink and it seems that NibeUplink provided the same 0.5°C accuracy outdoor temperature readings, ending with .0 and .5°C. New readings via myUplink end with .2 and .7 °C in my case
