Nice and cheap tablet wallmount
Hi all,
as I control my home via and Android tablet with Fully Kiosk installed, I was looking for a good wallmount. I searched the internet for days but did not find a good solution (there are some good solutions, but then you need to pay more for the wallmount as for the tablet and that is crazy).
Then I found a really smart solution which costs not more than 5 Euro. I used these transparent wallmounts for small stuff like a trashcan in the bathroom or something like that.
One piece is strong enough for 3KG and I used two for my Samsung Galaxy Tab A7.
At the end it looks like this:
So, very cheap and you don´t see the wallmount :slight_smile:
Hey, like the look! Wold you have the link whare to order the hooks?
Cheers luuk
Why not use velcro? Even cheaper and then there is less gap :wink:
Velcro is a tricky thing when mounting stuff vertically. The glue may let go over time - when you want to remove the tablet for service/other purpose it takes a lot of pull to take it off (since you need strong velcro for vertical mount).
If you really want the gap to be as small as possible, you could have the holes directly in the wall instead of using the plastic ones and slide the tablet “into the wall”.
I have my samsung tablet in the kitchen with velcro, works verry good, no glue coming off… 2 strips was more then enough :slight_smile:
These are the ones I used: https://amzn.to/39GEcVr
But there are a lot of similar hooks and I guess they are nearly all the same.
Also available on aliexpress for even less than on Amazon, but with a long delivery time.
