I’ve been looking for keypads that can be used to trigger scripts within HA, and for a switch that can send an “on” and “off” signal – i.e. I don’t want a toggle action.
I’ll start with the on/off: I have a Kasa bulb and Kasa smart outlet that I’ve set up and configured so I can control the lights in the bedroom with HA. Sometimes, however, you just want to tap something on the wall right there to turn the light on and not mess about with a phone or voice assistant, because that takes too long. Ideally, it would be a decora-style switch, where tapping the top would send an “on” signal, and tapping the bottom would send an “off” signal. I realize those labels are arbitrary, and I’m really looking for a 2-key keypad that looks (mostly) like a standard light switch. Worst case, if I have to use a toggle I can live with that.
For keypads, the best price/looks ratio I’ve found is the 2nd gen Bond Sidekick (with custom engraving). I was planning to pick up a Bond Hub anyway because we will be installing compatible blinds, and already have compatible fans. Is it possible to install multiple Sidekicks with a single hub, and can the keypresses be exposed so that I can write scripts in HA to react to them?
At the moment I’m running HA in a VM on my Macbook (setup was a breeze – far less complicated than getting the stupid Schlage Encode Plus working to connect to WiFi), but I plan to purchase one of the pre-built units and get the SkyConnect so ZigBee or Matter would be options also.
I’d prefer to avoid proprietary switches (e.g. Lutron or Leviton), and I’m only considering the Bond because I need their hub for the fans (I think). I don’t want to throw another hub into the mix, and all the nice looking solutions seem to be proprietary or “really proprietary and we’re not going to sell you a keypad without an entire system and if you have to ask what that’s going to cost, you can’t afford it.”
