Night stand lamp recommendation
What night stand LED lamps/lights do people use that integrate well with home assistant? I recently bought a LED color night stand lamp (https://www.amazon.com/gp/product/B07QK5K6CL/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1) but it doesn’t work well for automation since it doesn’t return to it’s previous state between switch toggles.
I saw the Moonside lamp (All Products – Moonside Design) which looks like it integrates with Google and Alexa. However, Mark Watt Tech mentioned (A UNIQUE Smart Lamp (MOONSIDE LAMP ONE) - YouTube) it didn’t integrate with HA yet, but that Moonside was working on it.
Any recommendations? Looking for a LED color lamp that will integrate well with HA.
Hue Go is a great lamp for that.
My 2c: any lamp can be controlled from HA if you use a smart bulb or switch.
The advantage: you have a much bigger choice in design, practicality, ways of placing, …
I have standard wall lamps which are dirt cheap with smart lighting, controlled by zigbee.
I bought a Moonside before starting my conversion to Home Assistant. Moonside has a cloud api as they have documented here Developer Center - Moonside. Connect the Moonside light to wi-fi and cloud control then setup a restful switch as described here RESTful Switch - Home Assistant. The api is basic on/off for now.
