Night state automation stopped working after update
Updated to 2023.10.5 last night and one of my automations has stopped working.
It’s triggers by the elevation of the sun to turn on or off a switch called night_state. Which I then use to turn on and off lights etc. has there been an update to automations that would stop this from working? Maybe it no longer recognised minus numbers?
alias: "Night State Update "
description: ""
  - platform: numeric_state
    entity_id: sensor.sun_solar_elevation
    below: -1.5
    above: -1.5
condition: []
  - choose:
      - conditions:
          - condition: trigger
            id:
              - below -1.5
        sequence:
            data: {}
              entity_id: input_boolean.night_state
      - conditions:
            id:
              - above -1.5
        sequence:
          - service: input_boolean.turn_off
            data: {}
mode: single
Check the trace (and log file) and see what’s happening
What is the definition of that sensor?
Why not using, e.g.
    entity_id: sun.sun
    attribute: elevation
    below: -1.5
From the very limited changes of 2010.10.5, it seems unlikely the release is actually the root cause of your issue.
Trace is blank because it isn’t being fired and log shows nothing about the automation.
The automaton has worked for 2 years faultless untill I updated to 10.5 last night.
Managed to get a working automation with this
description: ""
  - platform: state
    entity_id:
      - sun.sun
condition: []
  - if:
      - condition: numeric_state
        entity_id: sun.sun
        below: -1.5
    then:
        data: {}
    else:
        data: {}
mode: single
But still can’t see why the original stopped working.
What version were you running before updating?
I remember reading something about location and Elevation at some point. Is your location set?
2023.10.3 before updating. Yeah location is set and the entity was updating its elevation just for some reason the automation wasn’t picking up the change when it went below or above -1.5
