Are there some special config in the yaml file that I need for a ESP32-CAM with a night vision 850nm cam module to be used in the dark?
I have this camera (https://www.aliexpress.com/item/4000239046354.html) for a baby cam and it works great in the dark without showing the IR light. which my kid is scared of. However, it uses special cloud app software and it heats up and crash after 4-5 hrs of use. So I decided to recreate the same system using ESP32-CAM with some wide angle night vision camera module with ESPHOME firmware on Home Assistant. It all works great in the day time, but it wouldn’t see anything in the dark when I put it side by side of the above camera, as the camera IR light should provide the same IR light for both. At first I thought I got a bad cam module, so I bought serval more from different vendors with same result. Then I thought maybe is the IR light frequent, so I go some 850nm and 950nm IR lights. It is better with the 850nm. It can see some image but still very dark compare to the commercial one. So back to my question, what wrong with my setup??
Here is my yaml file setting minus the password stuff. It’s almost a standard setup. And thanks in advance for any advice:
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
# Image settings
# resolution: 800x600
resolution: 640x480
jpeg_quality: 10
max_framerate: 15.0 fps
idle_framerate: 0.5 fps
brightness: 2
contrast: 1
agc_mode: 128x
