Niimbot Label Printer Custom Integration
Niimbot Label Printer Home Assistant Integration
Installation
  1. Install this integration with HACS (adding repository required), or copy the contents of this
    repository into the custom_components/niimbot directory.
  2. Restart Home Assistant.
  3. Go to Settings / Integrations and add integration “Niimbot”
  4. Please select a discovered Niimbot device from the list.
Hi
Thanks for that integration :ok_hand: It would be nice to list printers that are supported by it :wink:
Also it looks like it supports only their printer that have network no ? I tried to add my 2 bluetooth ones but it doesn’t work :frowning:
Vincèn
The Bluetooth models B1 and D110 are supported. What is your current printer model?
D110 but it doesn’t detect it, will check while being nearer of my HA computer !
Is it able to work through Proxy BLE with ESPHome ? as it would make it a lot easier to use :slight_smile:
I confirm you it doesn’t work here ! Bluetooth is activated and working in HA but it doesn’t detect the Nimbot printer even when it’s just aside the NUC running HA !
Also error message is quite confusing as in French it states it could not find a printer on network…
Is the Bluetooth device not showing up like this? I will work on making the error message clearer. Also, Bluetooth proxy is supported.
oki so I found out that HAOS is not doing Bluetooth proxy even when bluetooth integration is activated. I have setup a Bluetooth proxy on one of my ESP.
Now when I try to activate the integration it “sees” my Fitness device but the printer doesn’t show up. If I check in ESP logs nothing shows up when I put on the printer aside the ESP :confused:
How do you handle the bluetooth part on your side ?
Vincèn
Is your Bluetooth printer paired with another device? If it’s already connected to another device, it may not appear in the list. Try testing it on https://niim.mmote.ru.
The Niimbot app on my phone but app is closed and not running, and the printer keeps blinking (the blue round) indicating it’s not connected at all !
One thing is sure: my BLE Proxy on ESP doesn’t see it at al :frowning:
How did you handle the Bluetooth part in your system ?
I am using the built-in Bluetooth of a mini PC and a Bluetooth proxy.
This is such a great integration. Thank you!
Is there a way to test the payload (the x y paremeters) before printing?
Currently, there is no way to test it before printing, but i will consider adding this feature in the future.
Do you plan to publish a custom card that would allow to use it easily ? as so far it’s quite annoying to use with the Action :frowning:
I haven’t created a custom card before, so I don’t have any plans for it yet. I’ll think about a way to make it easier to use.
B21 Supported?
I can’t say for sure since I don’t have the B21 model, but as far as I know, it works the same way as the B1, so I think it should be possible.
Thanks for this integration!
Do you know if it’s possible to put these printers (e.g. D110) into always-on mode? I mean, I would like it to be plugged into charger and always ready to print something (without having to turn it on or press any buttons).
I’m using the B1 model, and it can stay powered on continuously when connected to a power source. I think other devices might support this as well, but I haven’t tested them, so I’m not sure.
How long do you expect it to take from when the action is triggered to when the printer actually starts moving? I’m seeing 12-17 seconds, and that’s just for two lines of text, no images being downloaded from the web.
EDIT: Looks like it’s about the time to send over my BLE proxy (address obscured). This is the log for sending a bitmap showing 2 lines of text:
[16:38:05][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_CONNECT_EVT
[16:38:05][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_OPEN_EVT
[16:38:05][I][esp32_ble_client:263]: [0] [XX:XX:XX:XX:XX:XX] Connected
[16:38:05][D][esp32_ble_tracker:115]: connecting: 0, discovered: 0, searching: 0, disconnecting: 0
[16:38:05][D][esp32_ble_tracker:282]: Starting scan...
[16:38:05][D][esp32_ble_client:296]: [0] [XX:XX:XX:XX:XX:XX] cfg_mtu status 0, mtu 240
[16:38:05][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_REG_FOR_NOTIFY_EVT
[16:38:05][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_WRITE_DESCR_EVT
[16:38:06][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_WRITE_CHAR_EVT
[16:38:06][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_NOTIFY_EVT
[16:38:07][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_WRITE_CHAR_EVT
[16:38:08][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_WRITE_CHAR_EVT
[16:38:09][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_WRITE_CHAR_EVT
[16:38:10][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_WRITE_CHAR_EVT
[16:38:11][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_WRITE_CHAR_EVT
[16:38:12][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_WRITE_CHAR_EVT
[16:38:13][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_WRITE_CHAR_EVT
[16:38:14][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_WRITE_CHAR_EVT
[16:38:15][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_WRITE_CHAR_EVT
[16:38:16][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_WRITE_CHAR_EVT
[16:38:17][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_WRITE_CHAR_EVT
[16:38:18][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_WRITE_CHAR_EVT
[16:38:19][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_WRITE_CHAR_EVT
[16:38:20][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_WRITE_CHAR_EVT
[16:38:21][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_WRITE_CHAR_EVT
[16:38:21][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_NOTIFY_EVT
[16:38:22][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_WRITE_CHAR_EVT
[16:38:22][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_NOTIFY_EVT
[16:38:23][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_WRITE_CHAR_EVT
[16:38:23][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_NOTIFY_EVT
[16:38:23][D][esp32_ble_client:416]: [0] [XX:XX:XX:XX:XX:XX] Event 39
[16:38:23][I][esp32_ble_client:147]: [0] [XX:XX:XX:XX:XX:XX] Disconnecting (conn_id: 0).
[16:38:23][D][esp-idf:000][BTU_TASK]: W (454765779) BT_HCI: hci cmd send: disconnect: hdl 0x0, rsn:0x13
[16:38:23][D][esp-idf:000][BTU_TASK]: W (454765785) BT_APPL: gattc_conn_cb: if=3 st=0 id=3 rsn=0x16
[16:38:23][D][esp-idf:000][BTU_TASK]: W (454765789) BT_APPL: gattc_conn_cb: if=4 st=0 id=4 rsn=0x16
[16:38:23][D][esp-idf:000][BTU_TASK]: W (454765793) BT_APPL: gattc_conn_cb: if=5 st=0 id=5 rsn=0x16
[16:38:23][D][esp32_ble_client:191]: [0] [XX:XX:XX:XX:XX:XX] ESP_GATTC_CLOSE_EVT
The printer usually starts within 5 seconds. It’s slower than native apps, likely due to some delay in HA’s Bluetooth communication. In your case, the Bluetooth seems to have particularly high latency.
