Hello, I myself have only been using Deconz for a short time and two days ago I bought a Friends of Hue Switch from SENIC.
The connection with Deconz/Phoscon worked without problems and the switch entity is displayed in Home Assistant too.
The deconz events can be found in the developer tools under the events tab. Just enter “deconz_event” into the “Listen to events” field and start listening. Afterwards the events should be displayed when you press a key.
Thats my automations I made so far with it:
# FRIENDS OF HUE SWITCH OVER deCONZ #
- id: 'a_sw_1_1'
alias: 'Schalter - Büro - Deckenlampe toggle'
initial_state: 'on'
platform: event
event_type: deconz_event
event_data:
event: 3002
service: light.toggle
entity_id: light.buro_deckenlampe
- id: 'a_sw_1_2'
alias: 'Schalter - Büro - Deckenlampe start dimming up'
initial_state: 'on'
platform: event
event_data:
event: 3001
- service: script.buero_schalter_deckenlampe_dimm_up
- id: 'a_sw_1_3'
alias: 'Schalter - Büro - Deckenlampe stop dimming up'
initial_state: 'on'
- platform: event
event_data:
event: 3003
- platform: event
event_data:
event: 3002
- service: script.turn_off
entity_id: script.buero_schalter_deckenlampe_dimm_up
entity_id: script.buero_schalter_deckenlampe_dimm_up_loop
- id: 'a_sw_1_4'
alias: 'Schalter - Büro - Deckenlampe start dimming down'
initial_state: 'on'
platform: event
event_data:
event: 4001
- service: script.buero_schalter_deckenlampe_dimm_down
- id: 'a_sw_1_5'
alias: 'Schalter - Büro - Deckenlampe stop dimming down'
initial_state: 'on'
- platform: event
event_data:
event: 4003
- platform: event
event_data:
event: 3002
entity_id: script.buero_schalter_deckenlampe_dimm_down
entity_id: script.buero_schalter_deckenlampe_dimm_down_loop
- id: 'a_sw_1_6'
alias: 'Schalter - Büro - Deckenlampe Lichtstimmung wechseln'
initial_state: 'on'
platform: event
event_data:
event: 4002
- service: input_select.select_next
entity_id: input_select.buero_deckenlampe_lichtstimmung
- id: 'a_sw_2_1'
alias: 'Schalter - Büro - Schreibtischlampe toggle'
initial_state: 'on'
platform: event
event_data:
event: 1002
entity_id: light.buro_schreibtisch
- id: 'a_sw_2_2'
alias: 'Schalter - Büro - Schreibtischlampe start dimming up'
initial_state: 'on'
platform: event
event_data:
event: 1001
- service: script.buero_schalter_schreibtischlampe_dimm_up
- id: 'a_sw_2_3'
alias: 'Schalter - Büro - Schreibtischlampe stop dimming up'
initial_state: 'on'
- platform: event
event_data:
event: 1003
- platform: event
event_data:
event: 1002
entity_id: script.buero_schalter_schreibtischlampe_dimm_up
entity_id: script.buero_schalter_schreibtischlampe_dimm_up_loop
- id: 'a_sw_2_4'
alias: 'Schalter - Büro - Schreibtischlampe start dimming down'
initial_state: 'on'
platform: event
event_data:
event: 2001
- service: script.buero_schalter_schreibtischlampe_dimm_down
- id: 'a_sw_2_5'
alias: 'Schalter - Büro - Schreibtischlampe stop dimming down'
initial_state: 'on'
- platform: event
event_data:
event: 2003
- platform: event
event_data:
event: 1002
entity_id: script.buero_schalter_schreibtischlampe_dimm_down
entity_id: script.buero_schalter_schreibtischlampe_dimm_down_loop
- id: 'a_sw_2_6'
alias: 'Schalter - Büro - Schreibtischlampe Lichtstimmung wechseln'
initial_state: 'on'
platform: event
event_data:
event: 2002
entity_id: input_select.buero_schreibtischlampe_lichtstimmung
# END OF CONFIGURATION FILE #
Maybe this helps you a little bit with your configuration @Snex33 ?
It should be the same procedure whether the switch is from Niko or SENIC.
Greetings
