Nimly lock, with Zigbee module
Hi, any answers or new info regarding connecting the Nimly gateway to HA?
To change the sound volume of the lock when opening you can use this command.
0 will remove the beep when unlocking.
2 I believe is the default/factory setting
Same problem here. The lock works fine for at least a week or two but suddenly it is unresponsive via zigbee.
Any response from support?
I also have problem to get it to reconnect even if I pull the batteries. Have done it three times now but still doesn’t work. Perhaps I have to leave it longer?
I have firmware:
Firmware build date
20230914
Firmware version
4.7.75
Just got this lock home. Running zigbee2mqtt and skyconnect. The lock pairs and interviews but right after succesful interview it disconnects… i have tried re-pair it 50 times but no luck.
Zigbee2MQTT:info  2023-11-14 21:46:18: Starting interview of '0xf4ce3688a41c5161'
Zigbee2MQTT:info  2023-11-14 21:46:18: MQTT publish: topic 'zigbee/bridge/event', payload '{"data":{"friendly_name":"0xf4ce3688a41c5161","ieee_address":"0xf4ce3688a41c5161","status":"started"},"type":"device_interview"}'
Zigbee2MQTT:info  2023-11-14 21:46:18: MQTT publish: topic 'zigbee/bridge/log', payload '{"message":"interview_started","meta":{"friendly_name":"0xf4ce3688a41c5161"},"type":"pairing"}'
Zigbee2MQTT:info  2023-11-14 21:46:19: MQTT publish: topic 'zigbee/0xf4ce3688a41c5161', payload '{"auto_relock":null,"battery":null,"device":{"applicationVersion":10,"dateCode":"20230210","friendlyName":"0xf4ce3688a41c5161","hardwareVersion":11,"ieeeAddr":"0xf4ce3688a41c5161","manufacturerID":4660,"manufacturerName":"Onesti Products AS","model":"easyCodeTouch_v1","networkAddress":53268,"powerSource":"DC Source","softwareBuildID":"","stackVersion":10,"type":"EndDevice","zclVersion":2},"last_lock_source":null,"last_lock_user":null,"last_seen":1699998379031,"last_unlock_source":null,"last_unlock_user":null,"last_used_pin_code":null,"linkquality":164,"lock_state":"locked","pin_code":null,"sound_volume":null,"state":"LOCK"}'
Zigbee2MQTT:debug 2023-11-14 21:46:20: Received Zigbee message from '0xf4ce3688a41c5161', type 'readResponse', cluster 'genBasic', data '{"swBuildId":""}' from endpoint 11 with groupID 0
Zigbee2MQTT:info  2023-11-14 21:46:20: MQTT publish: topic 'zigbee/0xf4ce3688a41c5161', payload '{"auto_relock":null,"battery":null,"device":{"applicationVersion":10,"dateCode":"20230210","friendlyName":"0xf4ce3688a41c5161","hardwareVersion":11,"ieeeAddr":"0xf4ce3688a41c5161","manufacturerID":4660,"manufacturerName":"Onesti Products AS","model":"easyCodeTouch_v1","networkAddress":53268,"powerSource":"DC Source","softwareBuildID":"","stackVersion":10,"type":"EndDevice","zclVersion":2},"last_lock_source":null,"last_lock_user":null,"last_seen":1699998380187,"last_unlock_source":null,"last_unlock_user":null,"last_used_pin_code":null,"linkquality":168,"lock_state":"locked","pin_code":null,"sound_volume":null,"state":"LOCK"}'
Zigbee2MQTT:info  2023-11-14 21:46:20: Successfully interviewed '0xf4ce3688a41c5161', device has successfully been paired
Zigbee2MQTT:info  2023-11-14 21:46:20: Device '0xf4ce3688a41c5161' is supported, identified as: Onesti Products AS Zigbee module for EasyAccess code touch series (easyCodeTouch_v1)
Zigbee2MQTT:info  2023-11-14 21:46:20: MQTT publish: topic 'zigbee/bridge/event', payload '{"data":{"definition":{"description":"Zigbee module for EasyAccess code touch series","exposes":[{"features":[{"access":7,"description":"State of the lock","label":"State","name":"state","property":"state","type":"binary","value_off":"UNLOCK","value_on":"LOCK"},{"access":1,"description":"Actual state of the lock","label":"Lock state","name":"lock_state","property":"lock_state","type":"enum","values":["not_fully_locked","locked","unlocked"]}],"type":"lock"},{"access":1,"description":"Remaining battery in %, can take up to 24 hours before reported.","label":"Battery","name":"battery","property":"battery","type":"numeric","unit":"%","value_max":100,"value_min":0},{"access":7,"description":"Sound volume of the lock","label":"Sound volume","name":"sound_volume","property":"sound_volume","type":"enum","values":["silent_mode","low_volume","high_volume"]},{"access":1,"description":"Last unlock source","label":"Last unlock source","name":"last_unlock_source","property":"last_unlock_source","type":"enum","values":["zigbee","keypad","fingerprintsensor","rfid","self","unknown"]},{"access":1,"description":"Last unlock user","label":"Last unlock user","name":"last_unlock_user","property":"last_unlock_user","type":"text"},{"access":1,"description":"Last lock source","label":"Last lock source","name":"last_lock_source","property":"last_lock_source","type":"enum","values":["zigbee","keypad","fingerprintsensor","rfid","self","unknown"]},{"access":1,"description":"Last lock user","label":"Last lock user","name":"last_lock_user","property":"last_lock_user","type":"text"},{"access":1,"description":"Last used pin code","label":"Last used pin code","name":"last_used_pin_code","property":"last_used_pin_code","type":"text"},{"access":3,"description":"Auto relock after 7 seconds.","label":"Auto relock","name":"auto_relock","property":"auto_relock","type":"binary","value_off":false,"value_on":true},{"access":7,"features":[{"access":2,"description":"User ID to set or clear the pincode for","label":"User","name":"user","property":"user","type":"numeric"},{"access":2,"description":"Type of user, unrestricted: owner (default), (year|week)_day_schedule: user has ability to open lock based on specific time period, master: user has ability to both program and operate the door lock, non_access: user is recognized by the lock but does not have the ability to open the lock","label":"User type","name":"user_type","property":"user_type","type":"enum","values":["unrestricted","year_day_schedule","week_day_schedule","master","non_access"]},{"access":2,"description":"Whether the user is enabled/disabled","label":"User enabled","name":"user_enabled","property":"user_enabled","type":"binary","value_off":false,"value_on":true},{"access":2,"description":"Pincode to set, set pincode to null to clear","label":"PIN code","name":"pin_code","property":"pin_code","type":"numeric"}],"label":"Pin code","name":"pin_code","property":"pin_code","type":"composite"},{"access":1,"description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"easyCodeTouch_v1","options":[],"supports_ota":false,"vendor":"Onesti Products AS"},"friendly_name":"0xf4ce3688a41c5161","ieee_address":"0xf4ce3688a41c5161","status":"successful","supported":true},"type":"device_interview"}'
Zigbee2MQTT:info  2023-11-14 21:46:20: MQTT publish: topic 'zigbee/bridge/log', payload '{"message":"interview_successful","meta":{"description":"Zigbee module for EasyAccess code touch series","friendly_name":"0xf4ce3688a41c5161","model":"easyCodeTouch_v1","supported":true,"vendor":"Onesti Products AS"},"type":"pairing"}'
Zigbee2MQTT:warn  2023-11-14 21:46:20: Device '0xf4ce3688a41c5161' left the network
Got a message from Nimly support now.
They are developing a new firmware for the connect module that should solve the connect issues. They expected it to be ready in 2-3 weeks.
good… How will the update be performed?
To me they said that they will send a module with new firmware installed.
No OTA unfortunately… :frowning:
Well. Ota is of no use for me since i can not add the module… I just contacted the support. Not sure if i need to contact kjell och company also…
installed my Nimly Touch pro this weekend since I got a nice deal on Black Friday. Still waiting for my Zigbee module since they were out of stock at the store.
I got the entire package with lock, module and gateway but I have a question, can I use both the Gateway for mobile access and HA for automations etc. or do I have to choose one of them?
Yes they are seperate. Using gw for nimly app and zigbee for HA
Can you have several locks connected to the same gateway?
Any tips for pairing the lock with the gateway? I’m following the instructions to the point but I can’t get it to connect. The lock pairs perfectly with Sonoff USB Zigbee 3.0 E and HA using Z2M, so I assume lock and connect module is working.
Any update on this so far @nylund ?
Just managed to get my EasyCodeTouch to work with Conbee II (26780700)/ deCONZ :slight_smile: Had to manually install DDF, which was made for EasyFIngerTouch, but these all can use the same one, at least with basic functions (no HA interface for PIN management and NFC though :frowning: ) :
'easyCodeTouch_v1', 'EasyCodeTouch', 'EasyFingerTouch', 'NimlyPRO', 'NimlyCode', 'NimlyTouch', 'NimlyIn'
Had to use reset button on connect module to pair (hold until flashes quickly, then release. remove batteries. initiate pairing and insert battery. Kept it close to controller, but do not know if that is necessary).
Unfortunately no. I have asked for a status update but no reply yet. :frowning:
Yesterday I got a message from Nimly support that they have sent a new module. :slight_smile:
I hope it will solve the connectivity issues.
Did they send it for free?
Yep, for free :slight_smile:
But I would require that since my current module is useless for me.
I’m still trying to figure out if I can connect a Touch Pro to both HA (zigbee) and Nimly gateway at the same time. Asked the Nimly support and they said that it can only connect to one home-central aka gateway at a time, but that people on forums had gotten it working. Anyone here who have gotten it working? If so, what is your experience?
Got a new zigbee module, but this works just the same as the first one(020523 firmware). Connects to network when I connect the batteries, but disconnects after a couple of minutes.
I have Z2M container and use ConBee II adapter.
