Dielee
(Linus Dietz)
April 4, 2019, 10:13am
1
Hello guys,
i reverse engeering the ninebot by Segway app for integration in HA.
They use certifikate pinning and only trust system certifikates.
I used charles proxy and decrypted the login and data from the ninebot servers.
The caputred files can be found here: Github
At this time I can get access and refresh tokens from ninebot’s app servers.
But can not get data from ninebot servers, maybe somone can help me.
Dielee
(Linus Dietz)
April 4, 2019, 1:02pm
2
It looks like the ninebot app builds a one time token for fetching data. The used token isn’t usable anymore.
I don’t now how build this one time token.
You still around on this topic?
Hi, has anyone already tested this:
ownbee/ninebot-integration: Ninebot Scooter integration for Home Assistant (github.com)
A Cloud integration would also be usefull but I found nothing until now.
Boroda
January 28, 2025, 9:43am
5
Got any luck integrating ninebot into HA?
Hi everyone, wanted to share my progress which isn’t perfect but good enough for what I need.
Ownbee’s integration was foked by JoeyGE0 GitHub - JoeyGE0/ninebot-integration: Ninebot Scooter integration for Home Assistant and it works. Unfortunately it doesn’t update the values, but if you disable the integration and re-enable it, it will update the values 1 time. Spook integration from HACS allows for these actions.
Played with this for a bit and came up with the following integration. The premise is this - my scooter is hooked up to a smart plug with power monitoring capability. When the plug turns on (at a specific time in a separate automation), every 20 minutes (not the most efficient code) that the voltage is higher than a specific amount my automation gets triggered. The automation disabled the integration, re-enables it and checks the battery %. If its over 85% it turns off the smart plug. The thing that seems to make this work is when the charger turns on by the smart plug, the scooter connects automatically to BLE, I don’t need to manually turn on the scooter for the integration to connect.
alias: scooter integration charge
description: ""
triggers:
- entity_id:
- sensor.hive_2_power
for:
hours: 0
minutes: 20
seconds: 0
above: 39.4
trigger: numeric_state
- entity_id:
for:
hours: 0
minutes: 40
seconds: 0
above: 39.4
- entity_id:
for:
hours: 0
minutes: 60
seconds: 0
above: 39.4
- entity_id:
for:
hours: 0
minutes: 80
seconds: 0
above: 39.4
- entity_id:
for:
hours: 0
minutes: 100
seconds: 0
above: 39.4
- entity_id:
for:
hours: 0
minutes: 120
seconds: 0
above: 39.4
- entity_id:
for:
hours: 0
minutes: 140
seconds: 0
above: 39.4
- entity_id:
for:
hours: 0
minutes: 160
seconds: 0
above: 39.4
- entity_id:
for:
hours: 0
minutes: 180
seconds: 0
above: 39.4
- entity_id:
for:
hours: 0
minutes: 200
seconds: 0
above: 39.4
- entity_id:
for:
hours: 0
minutes: 220
seconds: 0
above: 39.4
- entity_id:
for:
hours: 4
minutes: 0
seconds: 0
above: 39.4
conditions: []
actions:
- action: homeassistant.disable_config_entry
target: {}
config_entry_id: 01JVQV2CB2NHM7S9G4MNW4HYH0
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
- action: homeassistant.enable_config_entry
target: {}
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
- choose:
- conditions:
- type: is_battery_level
condition: device
device_id: 07b5cf786e5672f078b804bf8a90c872
entity_id: 57f527b8399e253ad7fd73706344503d
domain: sensor
above: 85
sequence:
- action: switch.turn_off
metadata: {}
data: {}
entity_id: switch.hive_2
- conditions:
condition: device
domain: sensor
below: 85
sequence: []
mode: single
