Greetings-
Thank you for the great work on this component!!! I am however having the following issue.
Range is not updating automatically unless the car is charging. Now if I go into the Nissan Portal and perform an update then force HA to update it pulls the correct data. It is almost as if the Nissan Leaf Component in HA is not actually sending the command to pull the data from the car but just from the Nissan database.
I am still new and learning HA and do search before asking for help directly, but somethings are over my head or I don’t understand, forgive me if the solution is just out there and I don’t understand it. Thank you for your help.
