Nmap challenges
I have previously used Bluetooth for device tracking, but since I have moved from a Pi to an old laptop - which also has some ancient form of bluetooth, I have been playing around with NMAP. We have an IOS and Android device that should be tracked.
I have this in my config file:
  - platform: nmap_tracker
    hosts:
      - 192.168.86.27
      - 192.168.86.28
    consider_home: 1500
    home_interval: 4
This works great for the Android, but not so well IOS device. I am getting strange “Home” and then 10 minutes later “Away”, but that shouldn’t be possible with “consider home” set to 1500 sec? As I understand it, there should be a 25 minutes grace (1500 sec) from “Home” to “Away” should be possible? But that is not at all what I am seeing.
Have you double-checked to make sure you don’t also have a consider_home parameter set under devicename:?
Take a look at this custom component, it works better for ios devices.
I did have my devices also under the bluetooth tracker - same MAC adresses. After I removed the bluethooth tracker it works, so it must be interlinked somehow.
