I added all the devices in pairs, to check the result.
First: Tradfri + hue bridge - After restart automatically added to known_devices
second: switch + pi hole RPI - After restart automatically added to known_devices
Third: Desktop + laptop - No new devices
Im typing this on my desktop, checked the Ip trough Router and pc.
Im using Hassbian Home Assistant 0.66.1
EDIT: Tried adding my SynoNAS and an other Pi. Both work. Could it be that my laptop and Desktop are winsdows devices?
Host is up (0.00039s latency).
Not shown: 96 filtered ports
PORT STATE SERVICE
XXX/tcp open msrpc
XXX/tcp open netbios-ssn
XXX/tcp open microsoft-ds
XXXX/tcp open wsdapi
MAC Address: XX:XX:49:XX:D4:6B (Giga-byte Technology)
Nmap done: 1 IP address (1 host up) scanned in 14.02 seconds
It should be working then, double check that you have saved your changes (I have done this before) and maybe try another restart. With a short interval like 15 seconds it should have hit it multiple times by now.
I did a full reboot of the Pi, saved everything. Restarted router + PC.
Just added the edit to my first reply:
EDIT: Tried adding my SynoNAS and an other Pi. Both work. Could it be that my laptop and Desktop are windows devices?
@silvrr
I don’t know how but i tried Ping again and now its working perfectly… Registers my desktop and laptop withing 30 seconds from boot and 1 min after shutdown.
State changes work now. So ill be working with a mix of Ping and Nmap, depending on which works best for which device.
Any tips on the best Interval and Considerhome times? I have them set to 120 sec now.
