Hi all, I must start with saying I am new to this whole thing. So bear with me please. I am trying to set up the nmap component and it seems to not be loading. I tried using the Bluetooth tracker but had issues as well so Lets see what can be done.
This is on a Windows 10 installation of HA, Eventually I will set it up on a pi3, but am lacking the funds at the moment lol.
Thank you in adance!
this is the configuration I have.
#bluetooth tracker
device_tracker:
platform: bluetooth_tracker
interval_seconds: 12
track: true -
platform: nmap_tracker
hosts: 192.168.1.1-255
track: true
This is my Known devices file. (the second one was added by the Bluetooth tracker. It shows me a different mac address than my router or the phone itself is showing. I left both in to see if either one starts working.
windows_phone:
hide_if_away: false
mac: BT_xx:xx:xx:xx:xx:xx
picture:
track: true
windows_phone_2:
hide_if_away: false
picture:
track: true
So what is going wrong here? When I restart HA it will sometimes show Noah’s phone as home, even after turning off the phone or leaving for a while. About an hour AFTER restarting the server it turns my phone to “away” and there it stays.
Here is the log file from the last attempt.
16-11-30 22:08:51 homeassistant.components.device_tracker: Error setting up platform bluetooth_tracker
File “C:\Users\Mason\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\device_tracker_init_.py”, line 145, in setup_platform
if not platform.setup_scanner(hass, p_config, tracker.see):
File “C:\Users\Mason\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\device_tracker\bluetooth_tracker.py”, line 89, in setup_scanner
update_bluetooth(dt_util.utcnow())
File “C:\Users\Mason\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\device_tracker\bluetooth_tracker.py”, line 79, in update_bluetooth
result = bluetooth.lookup_name(mac, timeout=5)
File “C:\Users\Mason\AppData\Roaming.homeassistant\deps\bluetooth\msbt.py”, line 33, in lookup_name
return bt.lookup_name (address)
OSError: The operation completed successfully.
16-11-30 22:08:51 homeassistant.components.device_tracker: Error setting up platform nmap_tracker
File “C:\Users\Mason\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\device_tracker_init_.py”, line 136, in setup_platform
scanner = platform.get_scanner(hass, {DOMAIN: p_config})
File “C:\Users\Mason\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\device_tracker\nmap_tracker.py”, line 42, in get_scanner
scanner = NmapDeviceScanner(config[DOMAIN])
File “C:\Users\Mason\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\device_tracker\nmap_tracker.py”, line 75, in init
self.success_init = self.update_info()
File "C:\Users\Mason\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\util_init.py", line 296, in wrapper
result = method(*args, **kwargs)
File “C:\Users\Mason\AppData\Local\Programs\Python\Python35-32\lib\site-packages\homeassistant\components\device_tracker\nmap_tracker.py”, line 103, in _update_info
scanner = PortScanner()
File “C:\Users\Mason\AppData\Roaming.homeassistant\deps\nmap\nmap.py”, line 131, in init
os.getenv(‘PATH’)
nmap.nmap.PortScannerError: ‘nmap program was not found in path. PATH is : C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Users\Mason\AppData\Local\Programs\Python\Python35-32\Scripts\;C:\Users\Mason\AppData\Local\Programs\Python\Python35-32\;C:\Users\Mason\AppData\Local\Microsoft\WindowsApps;’
