Since a few days I get this error in my logs
Logger: homeassistant.components.nmap_tracker
Source: components/nmap_tracker/__init__.py:275
Integration: Nmap Tracker (documentation, issues)
First occurred: 09:25:47 (2 occurrences)
Last logged: 09:27:38
Nmap scanning failed: b'<?xml version="1.0" encoding="UTF-8"?>\n<!DOCTYPE nmaprun>\n<?xml-stylesheet href="file:///usr/bin/../share/nmap/nmap.xsl" type="text/xsl"?>\n<!-- Nmap 7.93 scan initiated Thu Sep 21 09:25:38 2023 as: nmap -oX - -F -T4 --min-rate 10 --host-timeout 5s --reason -v 10.0.0.64 -->\n<nmaprun scanner="nmap" args="nmap -oX - -F -T4 --min-rate 10 --host-timeout 5s --reason -v 10.0.0.64" start="1695281138" startstr="Thu Sep 21 09:25:38 2023" version="7.93" xmloutputversion="1.05">\n<scaninfo type="syn" protocol="tcp" numservices="100" services="7,9,13,21-23,25-26,37,53,79-81,88,106,110-111,113,119,135,139,143-144,179,199,389,427,443-445,465,513-515,543-544,548,554,587,631,646,873,990,993,995,1025-1029,1110,1433,1720,1723,1755,1900,2000-2001,2049,2121,2717,3000,3128,3306,3389,3986,4899,5000,5009,5051,5060,5101,5190,5357,5432,5631,5666,5800,5900,6000-6001,6646,7070,8000,8008-8009,8080-8081,8443,8888,9100,9999-10000,32768,49152-49157"/>\n<verbose level="1"/>\n<debugging level="0"/>\n'
I already removed the nmap integration and re-installed it, but the error keeps returning
HA 2023.9.2
