MQTT and Owntracks works fine. When I add nmap it overrides the MQTT location and displays on the map wrong location (100 KM away). Has anyone managed to use nmap and owntracks together? How to fix/ force right location for the nmap?
Thanks, Guy
Double check you coordinates at the top of you configuration.yaml.
Thank you very much!
It did solve the problem
Update 0.37.1 to 0.38.1 smack bam middle of London,
Zone doesn’t fix this???
I do live on main land Europe so howto fix it, seen the fact that soon London won’t be europe anymore.
Surprise surprise, after three times writing zone in it and 4 restarts of service zone did the trick.
