I have created an easy blueprint to control the office light (Trigger on motion, depending on lux and sun = action) .
After a while the light turns off. I need a second factor that uses the running infrastructre that is on anyway, to detect the running PC.
Nmap or Ping - I went for Nmap.
I have integrated it in the afore mentioned automation. It worked fine when I set my Linux in standby (home → not_home). Problem, when I switched off the PC the status didn’t change to “not_home”, so the light was on (home), according to the History of HASS
The Arcadyan Modem-Router of my Internet-SP, has no integration to HASS. The PC is connected to a switch, that I turn off together with the PC → no electricity. The Intel NUC (HASS) is connected to the Modem.
Is there a trick, how I teach HASS to change the status to not_home if the device is not reachable?
A follow up to myself.
Weird, the (home → not_home) worked now or was it the reboot?
I threw out everything below the sun state and created a new ‘choose’ section.
Now, the light stays on all the time I am at the PC, but it doesn’t turn.off when I shutdown the PC.
I am a bit lost right now, how do I get the HASS to challenge\question\restart the automation, when I shutdown the PC?
alias: Nmap-pc-centric-02c
description: ""
triggers:
- alias: When DesktopPC x470 changes from any state (null) to Home
trigger: state
entity_id: device_tracker.giga_byte_technology_31_66_9a
to: home
- trigger: state
entity_id: binary_sensor.lumi_lumi_sensor_motion_aq2_motion
to: "on"
conditions:
- condition: numeric_state
entity_id: sensor.lumi_lumi_sensor_motion_aq2_illuminance
below: 37
actions:
- choose:
- conditions:
- alias: Illumination from dawn (day time period).
condition: sun
after: sunrise
before: sunset
after_offset: "00:30:00"
sequence:
- data:
brightness_pct: 81
entity_id: light.tradfri_weiss_1000lm_light
action: light.turn_on
- conditions:
- alias: Illumination from dusk (night time period).
condition: sun
after: sunset
before: sunrise
after_offset: "-00:30:00"
before_offset: "00:30:00"
sequence:
- data:
brightness_pct: 69
alias: Choose light condition with sun
- choose:
- conditions:
- alias: PC off AND no-motion
condition: state
state: not_home
- condition: state
state: "off"
sequence:
- action: light.turn_off
metadata: {}
data: {}
- conditions:
- alias: PC on AND below 37 lux
condition: state
state: home
below: 37
sequence:
- action: light.turn_on
metadata: {}
data: {}
alias: PC off AND no-motion | PC on AND below 37 lux
mode: restart
trace:
stored_traces: 19
I would honestly suggest to start over from scratch and just use ping. No messing around with home & not home states for a stationary device - just a boolean which toggles to off(line) when not detected.
Well, according to HISTORY the Nmap works fine. So, I don’t want to start with another senor, plus Nmap can be used for other function as well.
Nmap is configure to scan-interval 50 seconds and 25 seconds marking a device.
Now, I am one step further. Light goes off, if PC goes to standby or off
My final problem, only one of the second “choose” section does get used. The one with the red arrow, never!
Conditions are AND, so I want to check, no-motion AND not_home, if both are true, turn the light off. Why not?
alias: Nmap-pc-centric-02d
- alias: PC off AND no-motion -=OR=- PC on AND below 37 lux
choose:
- conditions:
- condition: state
state: "off"
condition: state
state: not_home
sequence:
metadata: {}
data: {}
- conditions:
condition: state
state: home
below: 37
sequence:
metadata: {}
data: {}
- wait_for_trigger:
- trigger: state
entity_id:
- device_tracker.giga_byte_technology_31_66_9a
to: not_home
alias: Wait for trigger, PC changes from Home to Away
metadata: {}
flash: short
transition: 9
mode: restart
trace:
stored_traces: 19
The whole YAML code:
description: ""
triggers:
trigger: state
to: home
- trigger: state
to: "on"
conditions:
below: 37
actions:
- choose:
- conditions:
condition: sun
after: sunrise
before: sunset
sequence:
- data:
brightness_pct: 81
- conditions:
condition: sun
after: sunset
before: sunrise
sequence:
- data:
brightness_pct: 69
choose:
- conditions:
- condition: state
state: "off"
condition: state
state: not_home
sequence:
metadata: {}
data: {}
- conditions:
condition: state
state: home
below: 37
sequence:
metadata: {}
data: {}
- wait_for_trigger:
- trigger: state
entity_id:
to: not_home
metadata: {}
flash: short
transition: 9
mode: restart
trace:
stored_traces: 19
Another follow up to myself.
I don’t understand, why one of the ‘choose’ does work action: light.turn_on and the other does not work action: light.turn_off.
However, I found a “work around”. Change it from a State State to: a State AND Trigger.
Et voila, now it works.
In conclusion, the light stays on, as long as the PC is ON. The light will turn OFF, when the PC is in standby or off.
Motion, the motion sensor, does turn on and off the light as expected.
Nice side effect, I don’t need a mm-wave radiation permanently on my body, but the automation does, What I want. This function can also be used on a TV or TV-Box.
alias: Nmap-pc-centric-02e
description: >-
Motion-activated light, lux, sunset/sunrise, LED brightness + Nmap.
Illumination in conjunction of the position of the sun.
triggers:
- alias: When the Tower PC changes from Away to Home
trigger: state
to: home
- alias: Detect motion
trigger: state
to: "on"
conditions:
- alias: Room light gets below threshold
below: 37
actions:
- alias: Illumination (light) in conjunction of the position of the sun.
choose:
- conditions:
- alias: Illumination from dawn +30m (day time period).
condition: sun
after: sunrise
before: sunset
sequence:
- data:
brightness_pct: 81
- conditions:
- alias: Illumination from dusk -30m (night time period).
condition: sun
after: sunset
before: sunrise
sequence:
- data:
brightness_pct: 69
- alias: PC off AND trigger of no-motion -=OR=- PC on AND below 37 lux.
choose:
- conditions:
condition: state
state: not_home
sequence:
- wait_for_trigger:
- trigger: state
entity_id:
- binary_sensor.lumi_lumi_sensor_motion_aq2_motion
to: "off"
alias: Detected to Clear
metadata: {}
data: {}
- conditions:
condition: state
state: home
below: 37
sequence:
metadata: {}
data: {}
- wait_for_trigger:
- alias: Trigger waits for PC state change from Home to Away
trigger: state
to: not_home
metadata: {}
transition: 9
flash: long
mode: restart
trace:
stored_traces: 19
Any comment or idea is appreciated.
I hope my journey helps one or the other.
