A devices can easily have multiple entities.
How a device is defined is up to the integration.
Here it could be based on IP addresses and the numbers indicate that there might be 4 entities per device if they are evenly distributed, which is not a certainty though.
Devices is really not something you use much in HA. It is mostly entities you will be working with.
