No access HA
I forgot to start Lets encrypt after installation in Raspberry and I restarted Home Assistant. After restarting I can no longer access Home Assistant even though it works because I receive messages from automations. What can i do? Thank you.
Please tell what troubleshooting steps you have done yourself. Can you access it locally via ip? http://yourip:8123
You may also have to use https://192.168.0.42:8123 (with the actual IP) if you’re doing SSL in HA.
