No Access to Dashboard
Since that night I no longer have any access to my dashboard.
HA runs in a Synology VM and I can also connect via the shell. Commands like banner host info supervisor info and repair all work. All automations are running too. So basically everything is going well.
THE OBServer can be reached with LocalIP:4357 and everything is green
for LocalIP:8123 there is only an empty. response
I set it up as suggested by SIMON42 and made HA accessible internally and externally via subdomin.duckdns.org:8123.
Port forwarding in the router is still present.
However, pinging subdomin.duckdns.org:8123 does not work.
What else could I try now? Unfortunately I don’t have SSH access to possibly check the IP BAn list. Can I also try this from the command line?
Thank you
