Once you have made your changes, do a config check:
ha core check
If that passes, restart to commit the changes:
ha core restart
Alternatively, if you added the SAMBA addon your /config directory should be available on the network and you can edit the files from any PC on your network.
Hi Tom,
thank you!
I don’t have Samba installed and the cd /config command is not working from CLI interface.
What can I do to make the command work?
Thanx!
yes, its a standard raspy installation on a pi4. The HA> prompt only accepts HA CLI commands (Home Assistant command line), no cd or nano. Can I exit from that to get on the basic shell?
