rufneck
(numan)
October 27, 2019, 8:34pm
1
add-on store does not work
19-10-27 22:11:36 ERROR (MainThread) [hassio.store.git] Can’t clone https://github.com/home-assistant/hassio-addons repository: Cmd(‘git’) failed due to: exit code(128)
cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/home-assistant/hassio-addons /data/addons/core
stderr: 'Cloning into ‘/data/addons/core’…
fatal: unable to access ‘https://github.com/home-assistant/hassio-addons/ ’: SSL certificate problem: unable to get local issuer certificate
19-10-27 22:11:36 ERROR (MainThread) [hassio.store] Can’t load from repository core
19-10-27 22:11:36 ERROR (MainThread) [hassio.store.git] Can’t clone https://github.com/hassio-addons/repository repository: Cmd(‘git’) failed due to: exit code(128)
cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/hassio-addons/repository /data/addons/git/a0d7b954
stderr: 'Cloning into ‘/data/addons/git/a0d7b954’…
fatal: unable to access ‘https://github.com/hassio-addons/repository/ ’: SSL certificate problem: unable to get local issuer certificate
19-10-27 22:11:36 ERROR (MainThread) [hassio.store] Can’t load from repository https://github.com/hassio-addons/repository
It appears you have something blocking SSL or internet for that device.
rufneck
(numan)
October 27, 2019, 8:37pm
3
I’ve uploaded everything like in this video
Yesterday I had mqtt errors. Today I have installed ubuntu server and hass.io from the beginning. Now I have these errors
rufneck
(numan)
October 27, 2019, 10:23pm
5
kanga_who
(Jason)
October 27, 2019, 10:26pm
6
You have this error twice in that log, as @flamingm0e suggested, you have an SSL certificate problem. You either have something blocking SSL, or, you don’t have a valid certificate.
rufneck
(numan)
October 27, 2019, 10:28pm
7
how can i learn it? I installing 4. times ubuntu server. the same mistakes.
rufneck:
how can i learn it?
Do you have a web filter blocking things? Firewall? This probably isn’t an issue with home assistant but your network or computer.
rufneck
(numan)
November 3, 2019, 10:46pm
9
Is this problem because of the clock? Hass.io different clocks with some computer clocks.
hass.io utc time.
how do i solve this problem?
rufneck
(numan)
November 6, 2019, 9:54pm
10
The problem was caused by the modem. I have restored the modem to the factory settings. Resolved …
