No add-on store
add-on store does not work
21-03-11 17:06:40 ERROR (MainThread) [supervisor.store.git] Can’t clone https://github.com/hassio-addons/repository repository: Cmd(‘git’) failed due to: exit code(128)
cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/hassio-addons/repository /data/addons/git/a0d7b954
stderr: 'Cloning into ‘/data/addons/git/a0d7b954’…
fatal: unable to access ‘https://github.com/hassio-addons/repository/’: Could not resolve host: github.com
21-03-11 17:06:40 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / a0d7b954
21-03-11 17:06:40 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / a0d7b954
21-03-11 17:06:40 ERROR (MainThread) [supervisor.store] Can’t load data from repository https://github.com/hassio-addons/repository
21-03-11 17:06:40 ERROR (MainThread) [supervisor.store.git] Can’t clone https://github.com/home-assistant/addons repository: Cmd(‘git’) failed due to: exit code(128)
cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/home-assistant/addons /data/addons/core
stderr: 'Cloning into ‘/data/addons/core’…
fatal: unable to access ‘https://github.com/home-assistant/addons/’: Could not resolve host: github.com
21-03-11 17:06:40 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / core
21-03-11 17:06:40 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / core
21-03-11 17:06:40 ERROR (MainThread) [supervisor.store] Can’t load data from repository core!
Either your internet was down or GitHub was at that moment. Alternatively a DNS issue. Can you ping GitHub.com?
You have no working internet …
how can i solve?
because the internet actually works for me, the problem may be that I use a mesh router?
sorry for ignorance but what do you mean by `` ping GitHub.com ‘’ anyway for a short time a few weeks ago it worked
Have you got access to the command line. Either a keyboard and screen plugged into your device or using ash to access it from another device.
If so you can type ping GitHub.com
Press enter and it will attempt to communicate with that address and give you a print out of what resulted
Is your ha device plugged into ethernet?
si è collegato con ethernet, comunque ora provo a fare ciò che mi hai detto
Type ha network-info
You have no IP address listed above. Doesn’t look like your on the network
Try ha network info
same result
Can this be useful?
do i need to change some router settings?
You aren’t connected to the internet
So what should i do?
because some time ago it worked but after installing it again it does so, i also tried to uninstall it and try again
Same issue here. Started a fresh install, worked for a bit, stopped. Was still setting it up so I started over again with the exact same results. Works for a bit and then randomly stops. No way to resolve that I can find. Tried setting different DNS servers in GUI and via cli for the various docker instances and nada. So annoying and I’m regretting my decision to move aware from venv install.
Hello
Has anyone resolved this issue?
Same error occured to me:
I tried to restart the modem several times, tried to change the DNS, tried to change IP, tried to shut the firewall down, tried to format the SD, tried everything basically… but nothing works.
Can anybody help?
I have HomeAssistant HASSOS directly on Raspberry 4.
Your help would be much appreciated thanks
