No addons (official and community)
Hello everyone, I have reinstalled homeassistant (OS) a few days ago after I completely killed my supervised system a last week.
But since then my addon store is empty, no official and no community addons. Although these are listed as repository:
Can't add https://github.com/hassio-addons/repository, already in the store
For the community addons I could quickly find a fix, I just forked the repository and added the link.
GitHub - M123-dev/repository: Home Assistant Community Add-ons works and loads, so I guess it won’t be a dns or internet specific problem. However, the problem is that this trick does not work with the official addons
https://github.com/M123-dev/addons.git is not a valid add-on repository
Meaning, I have no way to install the official add-ons.
Does anyone have any idea how I can fix this problem.
My supervisor logs:
Click me
23-05-21 08:41:14 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-05-21 09:02:51 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-05-21 09:11:15 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-05-21 09:19:40 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-05-21 09:19:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.MULTIPLE_DATA_DISKS/ContextType.SYSTEM
23-05-21 09:19:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-05-21 09:19:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-05-21 09:19:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-05-21 09:19:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-05-21 09:19:40 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-05-21 09:19:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-05-21 09:19:50 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-05-21 09:19:50 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-05-21 09:19:50 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-05-21 09:19:51 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-05-21 09:19:51 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-05-21 09:19:51 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-05-21 09:41:15 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-05-21 09:51:31 INFO (MainThread) [supervisor.host.info] Updating local host information
23-05-21 09:51:32 INFO (MainThread) [supervisor.host.services] Updating service information
23-05-21 09:51:32 INFO (MainThread) [supervisor.host.network] Updating local network information
23-05-21 09:51:32 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-05-21 09:51:32 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-05-21 10:05:01 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/M123-dev/repository repository
23-05-21 10:05:02 WARNING (MainThread) [supervisor.store.git] No valid repository for https://github.com/home-assistant/addons
23-05-21 10:05:03 INFO (MainThread) [supervisor.store] Loading add-ons from store: 40 all - 0 new - 0 remove
23-05-21 10:11:15 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-05-21 10:19:51 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-05-21 10:19:51 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.MULTIPLE_DATA_DISKS/ContextType.SYSTEM
23-05-21 10:19:51 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-05-21 10:19:51 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-05-21 10:19:51 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-05-21 10:19:51 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-05-21 10:19:51 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-05-21 10:20:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-05-21 10:20:01 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-05-21 10:20:01 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-05-21 10:20:01 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-05-21 10:20:01 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-05-21 10:20:01 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
23-05-21 10:20:01 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
23-05-21 10:40:59 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/M123-dev/repository repository
23-05-21 10:40:59 WARNING (MainThread) [supervisor.store.git] No valid repository for https://github.com/home-assistant/addons
23-05-21 10:41:01 INFO (MainThread) [supervisor.store] Loading add-ons from store: 40 all - 0 new - 0 remove
23-05-21 10:41:16 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
23-05-21 10:50:34 INFO (MainThread) [supervisor.ingress] Update Ingress as panel for 23382f20_vscode
23-05-21 10:50:39 INFO (SyncWorker_4) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/vscode/aarch64 with version 5.5.7
23-05-21 10:50:44 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.0:1337 ssl:default [Connect call failed ('172.30.33.0', 1337)]
23-05-21 10:50:45 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.33.0:1337 ssl:default [Connect call failed ('172.30.33.0', 1337)]
23-05-21 10:50:57 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
23-05-21 10:50:57 INFO (MainThread) [supervisor.api.proxy] WebSocket access from 23382f20_vscode
23-05-21 10:50:57 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
23-05-21 10:52:14 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Received message 257:None is not WSMsgType.TEXT
23-05-21 10:52:14 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
23-05-21 10:57:26 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/M123-dev/addons repository
23-05-21 10:57:27 INFO (MainThread) [supervisor.store.git] Removing custom add-on repository https://github.com/M123-dev/addons
23-05-21 10:57:27 ERROR (MainThread) [supervisor.store] https://github.com/M123-dev/addons is not a valid add-on repository
23-05-21 10:57:30 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/M123-dev/addons repository
23-05-21 10:57:32 INFO (MainThread) [supervisor.store.git] Removing custom add-on repository https://github.com/M123-dev/addons
23-05-21 10:57:32 ERROR (MainThread) [supervisor.store] https://github.com/M123-dev/addons is not a valid add-on repository
23-05-21 10:58:15 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/M123-dev/addons repository
23-05-21 10:58:16 INFO (MainThread) [supervisor.store.git] Removing custom add-on repository https://github.com/M123-dev/addons
23-05-21 10:58:16 ERROR (MainThread) [supervisor.store] https://github.com/M123-dev/addons is not a valid add-on repository
23-05-21 11:01:56 ERROR (MainThread) [supervisor.store] Can't add https://github.com/hassio-addons/repository, already in the store
23-05-21 11:02:51 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-05-21 11:03:36 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/M123-dev/addons.git repository
23-05-21 11:03:37 INFO (MainThread) [supervisor.store.git] Removing custom add-on repository https://github.com/M123-dev/addons.git
23-05-21 11:03:37 ERROR (MainThread) [supervisor.store] https://github.com/M123-dev/addons.git is not a valid add-on repository
System Information
version core-2023.5.3
installation_type Home Assistant OS
dev false
hassio true
docker true
user root
virtualenv false
python_version 3.10.11
os_name Linux
os_version 6.1.21-v8
arch aarch64
timezone Europe/Berlin
config_dir /config
Home Assistant Cloud
logged_in true
subscription_expiration 12. Juni 2023 um 02:00
relayer_connected true
relayer_region eu-central-1
remote_enabled false
remote_connected false
alexa_enabled false
google_enabled true
remote_server eu-central-1-9.ui.nabu.casa
certificate_status ready
can_reach_cert_server ok
can_reach_cloud_auth ok
can_reach_cloud ok
Home Assistant Supervisor
host_os Home Assistant OS 10.1
update_channel stable
supervisor_version supervisor-2023.04.1
agent_version 1.5.1
docker_version 23.0.3
disk_total 57.8 GB
disk_used 6.3 GB
healthy true
supported true
board rpi4-64
supervisor_api ok
version_api ok
installed_addons AdGuard Home (4.8.6), Studio Code Server (5.5.7)
Dashboards
dashboards 1
resources 0
views 1
mode storage
Recorder
oldest_recorder_run 19. Mai 2023 um 16:05
current_recorder_run 19. Mai 2023 um 18:05
estimated_db_size 59.23 MiB
database_engine sqlite
database_version 3.40.1
It actually was a dns error.
Dns from the host system working perfectly
But requests from homeassistant did not, after changing the dns settings in the hass network settings it now seems to work.
